I have for sale a used Greddy PRofec B-Spec II Boost Controller. The unit was purchased in 2007, is in excellent condition and includes the wiring harness, boost solenoid and the original box/manuals. I've never had a single problem with the unit and it came recommended from my workshop (Unigroup) as one of the easiest and most reliable controllers to tune.
Based on the very popular B-Spec., the all new PRofec B-Spec. II's basic function to increase boost is as easy as the original, with an added built in boost pressure display and optional features like real-time, peak or last boost display (in either kPa or PSI). There are optional warning and boost limiter functions that can be programmed to offer much more control. The two presets values can be stored and are executed by a larger capacity inline solenoid valve. This unit does not require extensive programming and is ideal for low to high boost levels for single or twin turbos with actuator or external wastegates.
Price: $350 o.n.o
Item is located in West Pennant Hills. Please contact Ed on 0438 131 464.
**I am looking for a stock bleed valve for my S15 so anyone looking to part with one of these please let me know**
Edited by EzeKieL
Hey mate,
Reason for sale?
Are there any scratches on the unit at all (is that a scratch next to the select button?) Could you please take some more close up pics of the unit (top, front - etc) and also some pics of the the wiring - etc?
Also, please confirm that all wiring - etc required is included.
Cheers
Edited by KR4-GTR
Hey mate,
Reason for sale?
Cheers
Hi there.. I'm selling everything I own as I'm moving to Europe in August.
Sorry but the boost controller has now been sold.
    • Yeah so N1 and any other larger than factory pump are pretty famous for pumping the sump dry...obviously we don't often get to spend 20 or 30 seconds at high rpm/full noise on the road so I'd still be suspicious that is what is happening here.
    • You are also getting pressure dips on gear shifts. They're just not dipping as far, but they're dipping quite below the amount of oil pressure you should be seeing, for how much RPM drops.   It quite little could be the oil pressure relief valve is starting to stick open a little/is slow to close.
    • Can you log battery voltage, and TPS, and put all four of those into a single image (even as split graphs)?   The oil pressure drops aren't following RPM as such. I'm intrigued if you may have a ground loop between different sensors. With the engine not running, log your sensors and for example cycle the throttle pedal. See if any sensor values flutter or move about. This won't be a perfect test either as the ECU won't be cycling all of its actuators like it would be while running. What EMTRON do you have? Do you have a link to the wiring guide for that ECU?
    • What logic functions do you feel are missing from the Haltech that others have? Is there a limit to how much logic you can string together? By limit, I mean it's like only a single level or two levels of Boolean logic. Realistically, AND, OR, and NOT, is really the only logic you need and realistically, you can also do away with another logic gate of the three above . With those three you can build the full functionality of any Boolean logic you want.
    • Well that rules out the relocation theory, however with no load, you're still getting 1.5bar of oil pressure. Can you present that data in a scatter graph over longer period? Would really highly the anomalies. Wish Haltech could do that.
