I have some Blacktop SR20DET stuff for sale or swap came off a 60,000Km import 180sx
Also have CA18DE/T stuff listed below.
SR20DET stuff:
~ Stock RWD manifold with heat shield & stock dump pipe $60.
~ Stock Intercooler piping & Air intake pipe $20
~ Stock SR20 blacktop side mount intercooler forsale. $30
CA18DE/T stuff:
~ CA18DE engine. Previous owner reco'd head & new rings, appox 30,000k since reco'd said it ran really well.
Perfect for a DE+T conversion or keep it NA - Pick up only unless buyer organises freight. $600 [Pic #11] SOLD pending payment/pickup.
~ S13 CA18DE clip-in style injectors very good cond look near new with fuel rail - $100 [Pic #7-8]
~ S13 CA18DE side plenum with throttle body (bigger then DET) - $80 [Pic #10] SOLD pending payment/pickup.
~ RWD CA18DET Custom mild steel manifold $80 [Pic #1 & 2]
~ Nissan EXA Injectors & fuel rail - Sold.
~ CA18DET loom only missing main plug $50
~ Nissan EXA CA18DE Injectors & fuel rail $120 posted anywhere in aus.
~ Nissan EXA stock air filter box $40
~ Stock CA airflow meter. X2 $30ea
~ 4 injectors look like they could be GTR 444cc or CA18DET (3 yellow plugs 1 pink) (unknown cond but look ok, some damage should be fixed think it's pindle caps) $60 [Pic #9]
__________________________________________________________
Universal:
~ 3" Stainless steel de-cat pipe $40 [Pic #5]
Cooling:
~ FMIC (Front Mount Intercooler) Never used. Very minor defects but will not effect operation of the unit.
Specs: Bar & Plate 450 x 300 x 76mm with 2'5" inlet/outlets.
100% Vacuum Brazed Core. PM if interested. `~ price drop $190 ono [Pic #3]
Prefer pick up, willing to post at buyers expense (Australia only).
Most Pics below.
If interested or have any questions PM or email me powerrule((at))hotmail.com
1003593e.th.jpg 1003594v.th.jpg 1003536a.th.jpg 1002776e.th.jpg dsc03779d.th.jpg dsc03784.th.jpg dsc03798.th.jpg dsc03792a.th.jpg dsc03773e.th.jpg dsc03785.th.jpg dsc03810.th.jpg
Edited by Sports Crazy
Wont let me edit my first post?! Updated thread below.
SR20DET stuff:
~ Stock RWD manifold with heat shield & stock dump pipe $60. [Picture #6]
~ Stock Intercooler piping & Air intake pipe $20 [Pic #4]
~ Stock SR20 blacktop side mount intercooler. $30
CA18DE/T stuff:
Perfect for a DE+T conversion or keep it NA - Pick up only unless buyer organises freight. $600 [Pic #11] Sold!
~ S13 CA18DE side plenum with throttle body (bigger then DET) - $80 [Pic #10] On hold!
~ Nissan EXA Injectors & fuel rail - Sold!
~ Nissan EXA Injectors & fuel rail $120 posted anywhere in aus. On hold pending payment!
__________________________________________________ ________
Universal:
~ 3” Stainless steel de-cat pipe $40 [Pic #5]
TURBO's:
~ T28 Garret turbo suit rebuild (shaft play) includes actuator & some turbo lines! $100
~ T25 Garret turbo suit rebuild (locked fan) with polished housing includes actuator & some turbo lines! $100
Cooling:
Most Pics below.
  • 9 months later...
Hey mate was wondering how much it would cost to send the stainless steel de-cat pipe to Adelaide, Happy Valley 5159?
Oh and does that come with all bolts and gaskets or just bolts?
Also would that defiantly fit a 1991 180sx Type X?
Many Thanks
Justin Brimble
  • 1 month later...
  • 4 months later...
chasing the sr20 side mount intercooler piping, can you send any of that to cairns if i pay postage etc.
just need the pipes coming off the intercooler really, not all OF it, as its going onto a r31 skyline so im going to use larger piping anyway.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
