Hey guys i have a slight dilemma with my brakes/rims. I have put on a set of alcons both front and back with 6 pot at the front and 4 back. Mechanic has now realised my 3 piece rims dont fit. Problem i have is that ive had 6 different tyre shops tell me different offsets i need. Along with one telling me it will fit and another supplier telling me none will fit. Has anyone had any of the same issues with alcon brake kits ? the car is a r33 gtr. i dont understand what the offsets are or how to work them out etcc ive had the mechanic fill in the sheets from Work Wheels and they're saying they wont fit yet the guy who sells them says they will. Can anyone shed any light at all ? The size of the rims i have are 18' atm with 275mm tyres. apprently stock RX8 wheels fit on as they mechanic had them on the car to move it around the shop. though i doubt theyre the same width rim and tyre.
Cheers.
https://www.sau.com.au/forums/topic/278420-brakerim-problems/
It would help if you stated what the offset is.
There are two issues.
1. Getting enough room between the calliper & the spokes of the rim. This has nothing much to do with the offset.
2. Getting the offset right. From memory a number of about +12 is ok for a R33 gt-r (not sure) but you need also take into account rim width, tyre width, suspension camber.
Basically offset is all about how much of the cars track width the rim provides. A smaller number givers you a rim that sticks further out into guard which is a bit upside down but there it is.
I would tell you the offset but i have no idea what it was previously. the rims on there previously where a set of blitz 3 piece im not sure what offset they are. apparently +12 isnt going to work either.
I.m running +12 volk gtc in 18 inch on the front of mine. The 6 pot alcons fit with room to spare.
Its not even about offset. Its about disc clearance. R type disc I think is what you need.
Most Blitz rims have the size, offset, manufacture date etc cast into them on the inside of the hub. Take the wheel off & have a look.
Are you happy with the size/offset of the rims you have? Remember the calliper clearance is not related to the offset.
I have a set of Blitz rims that only just clear the front callipers on my GT-R. The Volk CE28's I also have clear them by a good half an inch in all directions. The rims are the same size & the same offset ie 17*9 +22. So changing the offset is not the key to fixing the problem.
See this for sizing.
http://www.nismo.co.jp/en/products/competi...pdf/wheel02.pdf
Edited by djr81
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
