ok put a new engine in my skyline rb20gts-t. started it... started ok for couple of days. then last two days when its cold it starts fine cranks over and runs on idle fine then i turn it off after 30min....go to put car in garage it wont start. cranks fine but no start..i have put new spark plugs, coil packs. the car is getting fuel so not fuel problem. changed computer so not computer. took oil cooler off cause i thought i could have connected it wrong. still same.. so what do you guys think? please help. could it be crank sensor? but if it was it wouldn't have started right?
cheers
car has bosch fuel pump, gt2876rturbo, full exhaust, pod filter, stock computer, fmic, if you need that info.
https://www.sau.com.au/forums/topic/278458-engine-starts-and-cant-start-again/
only starts when cold? sounds like my old car
Get the injectors cleaned out, it's not spraying enough fuel on start up hence the car isn't starting, when the car is warm, there is no fuel compensation.
Also, is your PCV plumped back into your cam covers and intake? having an atmospheric catch can setup and the PCV still installed will also cause problems when there's no positive pressure in the plenum.
yes only starts when its cold. and when it starts i run for 20-30 min switch it off. then i cant start it again. just cranks over.
i dought the injectors will need a clean, the car does start only when cold though, but i will check with mechanic about injectors, edit: with injectors they are pumping petrol as i can smell it heaps when it cranks.
whats a pcv?and i dont have a catch can,
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
