passenger side S2 r 33 door minus trim $200
passenger side S2 front guard $150
full set of S2 trims (2 door) $200
dash surround S2 $100
center consol S2 $50
rear seats S2 $50
fgk jasma muffler of r33 $100
open to offers
pick up adelaide
pm or txt 0409875003
https://www.sau.com.au/forums/topic/278466-r33-parts/
  • 4 weeks later...
