well Ive just had my manual conversion done and everything seems fine except for the gearbox making a whining/rubbing noise.
It makes the noise through 1st 2nd and 3rd gear but is ok in 4th and 5th. If the car is at idle it makes the noise but goes away when I push my clutch in.
I'm new to manual gearboxes so I Dont know much at all, so any help or info would be appreciated.
https://www.sau.com.au/forums/topic/278501-rb25-gearbox-noises/
Gearbox bearings for sure. Not a thrust bearing, as the sound goes away when the clutch pedal is pressed...disconnecting movement from the gearbox and leaving it the logical source of the problem.
Unless you've bought a gearbox with some straight cut gears, you've acquired a dud gearbox. Will need a recondition and probably cost you $1000 for the privelege. Sorry to be the bearer of bad news.
i have the exact same problem mine being main shaft and input shaft bearing are shot, i have play between the shafts, and will grind 5th 2nd and 4th. this happened to my car when i bought it thanks the previous owner not having enough oil inside. i replaced the gearbox oil with a fully synthetic oil and my box has lasted a over a year and is still going, the 33 box is a very strong unit in that year i covered 30k worth of highway, city driving, through the mountains, and plain straight out abuse by abuse i mean shifting from first to second to third as hard and and as quick as i could, and about a dozen burnouts to destroy worn tires after a full days worth of abuse.
if i was you keep the box till it blows by then have some cash saved up and build it tough so then you can forget about it, in the end its up to your but if you pull the box apart not to replace the bearings, you might as well replace the 10+ year old syncros (how ever you spell it) and then one or two of the gears might been worth so replace them two. get the idea if your going to pull anything apart to fix do it properly and it will save you in the long run, bty way im talking from experience and i hope this long post gives you an idea as to what to do.
    • Not alot of room in the front or mid pipe to play with Helmholtz chambers, plus they are pretty hit and miss getting the length and volume right, and time is money when it comes to trial and error testing at a exhaust shop, it isn't like test fitting mufflers or resonators From previous experience with exhausts and trying to tone down the volume and eliminate some drone, a resonator in the mid pipe typically make it much better,  and even possibly stop Jackie complaining about it, me, I really don't notice it that much, but, I am pretty deaf 🤣
    • I know it's an entirely different engine, but I noticed practically 0 difference removing or adding 2x 3in (5inch body) 400cell cats (one in each bank) with regards to sound. So changing the cat to change drone I suspect will have very very, very, very, very, very very minimal impact.
    • 200 cell cat will probably help. Do you have room to tee off a Helmholtz resonator anywhere along the exhaust? These can do wonders for drones, with a little experimentation with regards to length.
    • The car revs up through the gears much better/faster now, and fuel consumption doesn't really seem to have be affected either on a Hwy cruise, which wasn't expected  The FAB9 intake manifold has been problematic sourcing though, I've contacted Plasmaman to ask about their intake, which you can get different runner lengths spec'd, and, their different options for throttle bodies  The only real physical drawback with the Plasmaman intake is how to connect it to my current OEM style airbox, as FAB9 make a OEM style back half of the airbox to suit the larger diameter throttle body, and all that is required is a 30°bend silicone pipe to mate the throttle body to the airbox Car also goes in for some exhaust work in a week or so to fit the biggest resonator they can fit clearance wise in the front pipe to help remove some of the drone, there isn't alot of realestate under there, a rough guesstimation is it will only be about 3-400mm long and maybe 90-100mm diameter, and with a 60mm exhaust that doesn't leave alot of space for the internal volume of the resonator to do its thing I'm thinking I may need to bin the "high flow" 100 cell cat for something a bit more substantial, yeah, and restrictive, like a 200-400 cell, to help, but, I have ample room for a really large bodied cat to replace the current one which has around a 4" diameter body I may look around in the recycling bins and see if I can find a massive newish cat that was "replaced" with some new full exhaust system that the local exhaust shop in Western Sydney is doing
