OK well ive just had a manual conversion done on my car and now my windows are down and wont go up :-(
My question is when all the wiring was done with the manual conversion could there be something that was missed which would not make the power windows work, or would this be an un-related issue.
https://www.sau.com.au/forums/topic/278502-power-windows-not-working/
shouldnt have affected it.
unless u went near the door trims??
id check you connections behind the buttons on the door.
is it both controls? (passenger and drivers side) or just one side?
i had the same sorta problem... can you hear a click from ur drivers side door when u push the window down or up button???/
if u can id say its the little black relay box behind ur door trim cost like 25 bucks..... mind did both driver and passanger side
gl
