Hey there its time for me to depart with my R33 gtr
Im a mechanical technicain by trade
its running the standard airbox with hks2530"s A 3inch exhaust, and 15psi with no boost controller more of a permanet bleed system, so boost cannot be alterd, tuned it with nistune (32gtr ecu) to produce and easy 270rwkw an extremly conservative tune,
The car averages 420 km to tank with this tune, and is very responsive,
This gtr is still running the hicas system as i see no reason to remove it, as its not a race car , the car is extremly smooth and pleasent to drive,
Its still got the origional GTR dash wich only goes to 180 km hour, 142000 km on the clock
Has 18x265 Volk wheels wich stick like glue.
I have recently installed new Bendex pads all round and had the rotors machined,
Really this car must be seen to be appreciate, its clean origional and almost untouchable by the police, (exhaust might be a tiny bit over the 96db )
Come down to my workshop if you are genuinaly interested and ill put it on the hoist and ill let the car do the talking
dyno sheets available aswell
May trade for an auto turbo car of simlar value or cash my way,
dont really care if it sells or not im sick of changing gears though
price is $24000
the car is located in ferntreegully or rowville, VIC
cheers
post-42536-1247137597_thumb.pngpost-42536-1247137733_thumb.pngpost-42536-1247137869_thumb.pngpost-42536-1247138000_thumb.pngpost-42536-1247138032_thumb.png
https://www.sau.com.au/forums/topic/278508-r33-gtr-swap-or-sell/
Saw this car yesterday, and it is absolutely immaculate.
Owner knows exactly what he's doing too and has obviously maintained the car to the very highest degree.
The wheels are honestly some of the best wheels I have ever seen on a car too. These pictures make them look like ordinary silver 5 spoke rims, but there's a very nice inner blue lip decorated little silver plates which the pictures don't show.
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
    • blame old mate Hawkins for that one  I remember way back in the day the japanese didn't want them either... they always assumed a race shell would be thrashed. We found a few when looking for an R34 GTR for the Whites to drive in Targa Tas back in 2002.
    • I know it's probably not going to cause any major engine issues. I just had a more generic concern that it's technically not running right (I guess this means the rpm is not sitting where it technically should be) Though the other thing is, it's that my steering wheel is shaking at 1,100 rpm at idle until it gets warm (seemed to happen after I tightened my alternator belt, will be testing the alternator soon).
    • I mean, what's the concern here? Higher fuel consumption? FWIW my idle sits at around 800rpm or so as well. And yes, it runs fine, idles fine and there are no issues as far as I can tell. I don't quite see the problem.
