something different with 4 doors
great platform for track/drift car
its in decent condition for its age
pretty fast for what it is
will post pics + vid from last dyno day up on the weekend.
1991 Nissan Cefiro a31
5 speed
rb20det
170 rwkw
was in the middle of spraying it matt black. fitted with an autec front and rear bar. unknown sideskirts.
the front end is matt black and rest of the car is gunmetal (rear bar is white)
apexi AVCR (running stock .74 bar)
front mount
stock susp on king springs
plumb back bov
trust air filter
front strut bar
hd brass button clutch
After market fuel pump
brake upgrade
s15 steering wheel
still running NA exhaust so a change to 3inch would see more power
s15 rear wing
updated headlights/grille/tail-lights
GTR space saver
factory foggies
rego till sept/oct? cant remember
loads of other info which ill post later...
will be sold with skyline stockies
regularly serviced.
just changed oil/filter/plugs/fuel filter/replaced coil packs/o2 sensor and clean afm
hopefully should get some better fuel economy
was converted from a non-turbo auto to turbo manual from a r32 gtst m-spec II
i also have
-a set fixed bucket seats in red. One is smaller than the other.
one is for my frame (85kgs) the other was for my wife (50kgs).
currently has a sII r33 front seats.
-a ARC airbox to suit rb20det
which can be nego'd
ISSUES:
ill be honest
could do with a tune + spray
front shocks prob need replacing (easy fix as theyre replacable with s13/180)
syncros on their way out (prob easier/cheaper to replace the box)
she's a bit rough but she pulls hard...
$7500 ono... make an offer.. who knows...
also open to trades (CAR OR BIKE) + cash
the cash part is important because i need money to pay for medical expenses for my dad.
contact: sms 0403 488 582 (sms is the best option because ill be in the hospital most of the time)
Edited by r32-
https://www.sau.com.au/forums/topic/278541-nissan-cefiro-91-a31/
  • 4 weeks later...
    • Are these a plug and play setup, and do they need a tune, like a haltech ecu etc? Thanks
    • Nice work on the paint. Those 3 studs are long as.
    • Hi everyone, still chasing a bunch of this stuff. Thanks
    • Been over 2 months since I have done anything on the S15 and had a day off today so got stuck into mounting the radiator and intercooler. I ended up using factory bottom mounts as bolted in and I did order some gktech top brackets but didn't work with the PWR radiator so made up some with aluminium flat bar. Spent way to long on them but pretty happy how they are. Next job was the intercooler. Used some more aluminium flat bar and did the bottom mounts first. Top was easy as just one long piece and 2 90 degree coming off rad support and welded them on. The bumper support required some notching to let the outlets sit where I want so will add some reinforcement later to strengthen it. I have also bought ecu and waiting for it to arrive. Went with a Link g4x Xtreme but will be adding a ptmotorsport expander to add a few extra inputs over CAN. Went through a few different configurations on pclink to get what I want to allow future expansion for sensors and gearbox upgrades. Ordered gktech rear arms but looking at the hardrace lower control arms to have some extra adjustment too will see how the alignment looks after first setup. Got 2 more weeks of work before shut down and will have almost 4 weeks to work on this so planning on hopefully firing up mid January.   Also bought a 2015 brz with a heap of good gear, did noosa hill climb a month back. Owned it for 3 days changed alignment and sent it. Finished the weekend 2nd in class and only .3 off the 180sx best time last year. MCA Red coilovers, gktech rear lca, bolt on lock kit and tie rods, whiteline toe arms, cusco 1.5way diff and 4.5 ratio, endless brake pads, headers, exhaust, perrin intake and e85 tune. Electronic steering adjustment, nankang crs with koya wheels 17x9 +35. Have bought rear traction arm and relocation kit, extended studs and v3 tie rod kit. Planning on also getting flex tune as lucky to get 300km a tank with e85 and short ratio. Car is a heap of fun to drive and super easy to work on. AC in the line up at Noosa was mint in 35degree weather.
    • I'm 22 years younger than you mark, and I'm operating in the exact same way! Ha ha ha
