Was looking at these mags:
But they only come in 9inch wide - is that too wide for my r32 GTST at the front? - i dont want guard rub :thumbsup:
And would i be able to stretch 215/40/17's on them too?
And lastly, my cars not low at all - so would that aid in being able to fit them?
They are 17x9 - 30 offset
Im not clewed up on mags, so it really is a guessing game for me...
Edited by Flux_nz
https://www.sau.com.au/forums/topic/278546-will-these-mags-fit-my-r32-gtst/
are you sure it's -30 and not +30?
there is no chance -30 will look anything short of ridiculous, but +30 is achievable.
i wouldn't personally put 215s on there but if you were so inclined you could
+1
9inch +30 with scrub on the rear (if lowered). Will need to roll the guards or have some negative camber.
They will also scrub on the front depending on height.
I had +30 8inch on the front with 235/45 tyres and it would scrub. Dropped to 225 and scrubbing went away. Yours are 1inch wider so would scrub much easier in my opinion.
9inch +30 is the same design as R33 GTR rims. So best to ask any r32 gtst owner with r33 gtr rims and they will tell you a deffinite answer on fitting.
I have R33 GTR wheels on an R32 gtst with 245/45 rubber, standard-ish ride height with stiffer shocks & springs, i had to get rears rolled (not lipped) and have had no scrubbing what so ever.
Front is a different story..... 245's on the front, standard guards untouched, only when i hit a big dip or bump does it slightly scuff something on the tyre, it hasn't chopped sidewalls (I cannot see any damage what so ever to the tyre's), i use to have a pair of tyre's on the front with worn shoulders and it never scrubbed once over anything.
Tyre's rubbing shouldn't be your main concern, just slap 235's maximum on them and you should be fine with standard-ish ride height. (My 245's stick out front the guards at the front and would probably be deemed unroadworthy, next set of tyres are going to be 235's)
I would worry about the +30 offset rims effecting your roll centre and what it does to your steering & suspension.
+30 changes your roll centre and steering becomes more 'darty' over ruts and divets on the road. (each front wheel wants to roll around bumps instead of travelling up and down over them). This means constant corrections have to be made to keep it going straight. 12 months have past with the wheels on and i have had to replace steering rack bushes from all the extra movement in the rack.
Other bushes at the front have probably been prematurely worn because of the wheels.
They look fat and grip great on the twisties and track but are very compromised on the road.
More solid steering rack bushes at the front have helped quite a bit but I wouldn't recommend +30 offset on a car that has to be driven daily in the city unless you like the steering wheel jumping out of your hands.
Just my 2 cents
Just my 2 cents
i had the tramlining issue with 235/45's on my +30 rims. Steering wheel would pull into any ruts in the road etc, was annoying to drive with.
However after dropping to 225/45, adjustable camber bushes,adjustable castor bushes and a proper alignment, the tram lining disappeared and have no issues.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
