-->> R34 Nismo 480cc Injectors <<--
Hi guys,
Putting my Nismo 480cc injectors up for sale. Top feed, 4 hole spray pattern, very nice atomisation.
Should be good for 300rwkw, and could be pushed a bit if you are also running an adj fuel pressure reg
I got these second hand from japan (off a Z33) and i would have only used them for say 1000km's, if that even.
Worked flawlessly, no issues what-so-ever and installed and taken out by the boys at Status Tuning. No diy, only the pro's installed/uninstalled these.
Very hard to find and one of the few good options for the NEO RB25DET. 4 hole spray pattern is much nicer than the sards, etc - ask your tuner :)
Price: $750 (check out the brand new prices of these, $1300+)
the boxes are just the ones they came with from japan.
cheers,
daniel
switched to E85 and which means it's running approx 30% more fuel - doing figures like 480cc = 480hp = 358kw, less a bit for drive train = 310-320rwkw
that's ok for pump fuel, E85 won't fit into that equation unfortuantely - so up i went. Bit disappointing to lose the nice spray of the Nismo's, but trade off in idle/tuning and probably consumption had to be made.
PM sent
i know RB20DET's are top feed, but i wouldn't think these would fit directly. I've never seen it mentioned before.
eg. R34 GTR injectors are top feed, but won't fit in the NEO RB25 (well, won't fit directly)
i guess you could make them fit, but you might need to search the 'forced performance' section to see what needs to be done. Who knows, might be an easy fix
cheers,
daniel
will have to check my records :down:
tuning time depends on if the car plays ball :bunny:
you can install them yourself, but you'll either have to tow the car to the tuners, or play with your ECU if you've got control over it, just enough so you can drive the car to the tuners.
 Share
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
    • Id like to race in the US i think alot of those track would suit me   For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
