Hey fellas and to Chris R.
I need help with my car issue hoping you guys can give me a bright answer.
Anyway, if you notice with our windows, when you open the door, the window slightly moves down abit (about 1 cm) and when you shut the door it goes back up. (just like eauropean cars.)
I got my car back from an importer for a bumper respray and somehow my window is fuxxed. So when I open the door (passenger side) I noticed the window has gone down to about 2 cm's and when i shut the door, the window does not go up! So if you can imagine…the window get lower and lower every time I open the door and I just need to manually controll it or shut it.
Do you guys think that this has got to do with the window motor or the Body Control Motor/Unit? or more likely the wiring?
Thanks in advance.
https://www.sau.com.au/forums/topic/278599-help/
Hey Ogz,
Strange for it to happen after some paint work but the window motor's in these do go....have you tried anything to fix? the window up and down on door open/close works in with the door switch, it wasnt disconnected for paint work was it, or not properly re-fitted? Have you put it all the way up, disconnected the battery then reconnected to see if it will reset? Just a few ideas, otherwise could be the motor, dont know too much in this area. Good luck.
https://www.sau.com.au/forums/topic/278599-help/#findComment-4706981
Thanks for the input Sky, yeh we have tried resetting the window and no success on that, tho im not 100% sure about the success rate on disconnecting and connecting the battery for a reset?..hmm .. I brought it to an electrician, but I wasn’t very satisfied with his suggestions. I went and saw this guy twice and during that time he tells me 2 different stories.. So I thought to consult chris virtually and fellow V35 owners for some bright inputs.
https://www.sau.com.au/forums/topic/278599-help/#findComment-4707009
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
