I had this problem too, does it work intermittently by any chance? Or does not work at all?
If it doesnt work at all, it may simply be disconnected during compliance.
Slide it back towards you, lift it up, fish around for the cable and re-connect.
It tends to be dicky, the cable, so it will probably be about 80%
my car came with spoiler (sedan) with the brake light on that. I also had the brake light inside the rear windscreen which was disconnected. when i took off my spoiler i had to reconnect the plug for the inside one to work.
dunno if that info helps.
thank you guys, the 3rd brake light is not work at all. (After I connet the cable)
I think I need to buy a new LED light to fix,but there are looks like hard to take it out????
anyone try to take it out before??????Pls give me some idea.
Or any one know where can buy the new brake light or spolier?
(BTW: can drive the car without 3rd brake light on the road?)
To V35ADC, any update on these? I may have the same problem.. =( suxx.. hmm would anyone have any idea how we go about fixing the LED on our 3rd break lights?.... anyway i better start my re-search yet again..
this week has been a rough week for me, ive got the similar story with the 3rd light as sometimes it works sometimes it doesnt and other times its not as bright.
while driving on a 60km rd on tuesday in morning still kinda dark a huge chunk of brick was left right in the middle of the rd by construction builders, lowered v35 going 60km/hr over it, broke something underneath and i need to get it repaired as its hanging loose on the bottom.
Ouch! I hope there wasn't too much damage...
On another note...can anyone enlighten me why in the world compliance would need to disconnect 3rd brake lights???? Isn't a 3rd brake light compulsory nowadays? I can understand d/c the xenons...but the 3rd brake light...wtf???
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
