I had this problem too, does it work intermittently by any chance? Or does not work at all?
If it doesnt work at all, it may simply be disconnected during compliance.
Slide it back towards you, lift it up, fish around for the cable and re-connect.
It tends to be dicky, the cable, so it will probably be about 80%
my car came with spoiler (sedan) with the brake light on that. I also had the brake light inside the rear windscreen which was disconnected. when i took off my spoiler i had to reconnect the plug for the inside one to work.
dunno if that info helps.
thank you guys, the 3rd brake light is not work at all. (After I connet the cable)
I think I need to buy a new LED light to fix,but there are looks like hard to take it out????
anyone try to take it out before??????Pls give me some idea.
Or any one know where can buy the new brake light or spolier?
(BTW: can drive the car without 3rd brake light on the road?)
To V35ADC, any update on these? I may have the same problem.. =( suxx.. hmm would anyone have any idea how we go about fixing the LED on our 3rd break lights?.... anyway i better start my re-search yet again..
this week has been a rough week for me, ive got the similar story with the 3rd light as sometimes it works sometimes it doesnt and other times its not as bright.
while driving on a 60km rd on tuesday in morning still kinda dark a huge chunk of brick was left right in the middle of the rd by construction builders, lowered v35 going 60km/hr over it, broke something underneath and i need to get it repaired as its hanging loose on the bottom.
Ouch! I hope there wasn't too much damage...
On another note...can anyone enlighten me why in the world compliance would need to disconnect 3rd brake lights???? Isn't a 3rd brake light compulsory nowadays? I can understand d/c the xenons...but the 3rd brake light...wtf???
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
