Lol Funky, that's the one. So there's no way to get rid of the surge? I either have to live with it or get a stock bov?
My bov was leaking so that's why I replaced. And how bad is this for the turbo? Is it just bouncing around in the pipes or would it actually hurt the turbo?
I've noticed it pop sometimes but is that just flames or is that a small backfire? (backfire's shocks would hurt the turbo...)
Edit: I'll try to upload a video of the sound it makes and how it's set up this friday as well.
Edited by Nasedo
https://www.sau.com.au/forums/topic/278645-new-bov-surge/#findComment-4713812
It wasn't, I bought it from Repco in NZ. Not everyone can afford to spend $500 on a blow off valve. Especially when it's not needed yet.
Well my mechanic advised me that the stock one was leaking.
If it doesn't hurt the turbo then I don't really care what it sounds like, but that's my main concern. If this is what it's meant to sound like then that's fine with me.
Thank you for all your support and input everyone. :P
Edited by Nasedo
https://www.sau.com.au/forums/topic/278645-new-bov-surge/#findComment-4715243
I have been running my blocked off BOV on my RB25DET for about 2 years now and no problems what so ever.....still running the same stock turbo and 12psi through it daily mate.....
If your after a BOV then i have a GFB Stealth FX up for sale mate.....PM me if your interested.....
http://www.subaruxtras.com/subaru/images/1009red.jpg
Thats what it looks like....and its got an option of either plumb back or atmo...
https://www.sau.com.au/forums/topic/278645-new-bov-surge/#findComment-4715347
If you are certain this is a surge sound, I am guessing your BOV is incorrectly installed.
OR
Are you positive your stock one was leaking? Perhaps it was actually the vacuum line leading to it (leaking/disconnected), hence the new BOV isn't opening.
https://www.sau.com.au/forums/topic/278645-new-bov-surge/#findComment-4715372
    • Unless you have big cams, there is no reason for an RB to idle at any more than the stock 650. No, it is not 850, 950, or anything else. It is 650. In fact, it might even be 550. I just opened an arbitrary stock Neo file in Nistune, and this is what I see
    • I love the undertray, especially the flappy bit for easier access for serving I'm thinking of fabing up one at work for the MX5 while I still have access to the metal shop at work with a guillotine and press brake Whilst removing the plastic undertray on the MX5 isn't to hard, I love the idea of a 2 bolt flap as opposed to removing the whole thing
    • Great thank you for that. Yeah that is the bumper and spoiler it still has i just hadn't heard of it being referred to as a aero form bumper before. Really appreciate your help.
    • A little progress; I took the opportunity of an oil change to take a sample for oil analysis, will be interesting to see how it was treated for its first 125,000klm (I know how it has been treated since :rofl:) I went with 5w40 and will see what that does for oil pressure at higher revs. Also fitted the Z1 front undertray....a little more sturdy than the plastic factory one (although I suspect it won't stop a tree stump ) Nicest thing about it really is the 2 bolt "service panel"....a gift to the oil changer compared to removing 14 bolts holding the factory tray.
    • I think a scissor lift is better/faster in most cases, but I guess it does obstruct access to the centre of the car? BTW I weighed the quick jack. 3.5 tonne model is 50kg for each side. So yes, portable, but not with one finger
