*sigh* I'm feeling a little sickened by these videos... and taking your car to the track without the knowledge to do it safely is just dangerous...
Almost reminds me of the The land of goat sphincter rings Airlines that are banned from Netherlands Airports because they have no safety standards (only taking minimum fuel and thinking that requesting emergancy priority landing every time they hit a headwind is acceptable)
  • Replies 79
Im one that will also go with a "your attitude is shit" comment. You blatantly tagged the s2000 and caused it to hit the wall. Bad strip or not, your car was poorly setup and you caused them to crash. Instead of fixing your car and bragging about that great time, you should be fixing theirs.
I run these same tyres on my car doing an 11. So do a lot of guys i know running 10's and 11's and they are ok to run with a radial (i dont think its reccomended however) but anything under 9psi is getting horribly dangerous in my experience. 7.5psi on an unprepped track is asking for trouble.
Ive done well over 100 runs on the strip with slicks and these tyres are pretty hard to drive for a start, but psi that low is absolutely nuts. Friends with dedicated drag cars rarely run that sort of psi on prepped tracks in the middle of summer.
In the early stages i was trying to help this guy...but very quickly found that he didn't listen to what was being advised so i pulled the pin on helping him out.
My perception that you are a d1ckhead mate has now been confirmed.
Stay off the track...the sport does not need you.
9krpm
All us drag forums said to remove the front sway bar.
freshalloys.com all guys there remove the front swaybar for better et's. As the cars without front sway make a better stand back!
Anyway I will put it again.
Ok guys I understand about tires.
I know that it is very difficult to control the car with less than 10psi at tires but... :D:):D
The grip of the street was like shit!!
And I wanted to do goot et's so.. good times :D :D
I know that it was dangerous pressure :( :(
DiRTgarage Thank you for your good words!! :| :| :|
9krpm
Heres some more good words for ya. f**koff you dangerous idiot.
I wont' even ask what wheel alignment you had on the car.
I did but didn't get a response. My guess is still that an alignment hasn't been done and the rear toe is everywhere. Between that, running cross ply without front runners and deciding not to get off the throttle when it all started going to shit.
Agreed, thank god this isn't local and in a skyline. The media would be all over us for something this silly.
then you and the us drag forums have a total misunderstanding of what a sway bar does. It can only transfer force between the 2 wheels it links, therefore it makes absolutely no difference in a straight line.
Lol Paul,
Dunc - The guys that remove the front sway bar usually have a live rear end and it can help the car squat a bit harder on the right hand rear tyre
like here A%20hard%20launch%20for%20the%20amazing%20USA-1%20Camaro.%20Photo%20by%20Dave%20Milcarek.jpg
....would be absolutley pointless on an IRS car though
I think he somehow might has toe in/neutral though. If the toes were out in the rear, I would expect his car to be more out of control when it came on boost earlier on the track.
Anyhow, regardless of what alignment it had, the combination of heavier front (+ wrong tyre combination) and the lack of sway bar means that the rear tyres were almost in the air once the brake were applied. The suspension system was obviously poorly engineered and hence the accident.
Rear aligment
Camber 0.5 possitive to be 0 at the time of the launch
Toe 0 is it ok this?
Front
Camber -1.5
Toe +0.5
Caster +7
you need to determine the dynamic toe especially with +ve camber as the suspension arc will alter the toe settings as your car squats under power. Setting a car up like this we would usually set it up on the wheel aligner without the rear struts and raise / lower to gauge its change in geometry over the range of travel, this is the only way to get the optimum alignment specs.
mate give up and go home stay off the strip, u can see you car all over the place way before the crash and u still pushed on and caused this,
why you running those tires anyway its not like you need them on a car that requires alot more setup before you even think about these tyres mid 11's isnt that fast to require removing your front sway bar for weight saving gee why dont you just chuck out the front seat and use a milk crate to sit on? im sure that will get you in the 10's and dont worry when its all ova the place halfway down the strip just hold it flat untill ur facing the start line again.
Edited by Travis Trayhern
I don't see how he can keep saying he did NOT clip the honda.
you can see it and you can hear it.
and if the honda didn't swerve and kept going straight, you would have clipped it further up the body.
Just a question..
but were either of the drivers wearing a helmet?
I still can't comprehend the reaction of the S2k driver.. swerving slightly is one thing but she full turned into the barrier, looked like she almost hit it square on the front!
I wouldnt even be racing on a track like that, we have it pretty good here, and yeh the s2k did swerve pretty violently, swearving like that at those speeds alone would put you off the track i reckon, but yeh you take it to the track you take it upon yourself, thats why every improved production driver ive talked to dont do open track days cause they dont trust the car or the talent of other drivers
its good that both of you walked away RIP s2k
  • 1 month later...
i almost forgot about this entertaining thread, great resurrection
the above quote is awesome, my mates gokart racing up at picton does exactly this
Jesus, this was never going to end well.
A pathetic excuse for a drag strip, a terribly unsafe death trap car that was not properly prepared for the track, and an ignorant driver who was not capable of handling the car.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
