I don't clicked the s2000!
My front bumper doesn't have nothing...
the s2k had already started to swerve to try to avoid you. At 5mins in that video you will see this image and the sound of you touching the s2k
  • Replies 79
Well that would explain why the car was wobbling the rear end all over the place, Thats the reason why ANDRA specify a cross ply front trye must be used if on slicks going faster than i think 12 secs or is it 12.5?
Yes I am thinking the same thing.
Greece, if you have a Nismo 2 way diff then the accident could have been avoided with better brake control. I speculate that you left it too late to back off the throttle, panicked and then slamped on the brake when the rear end lost control. This just sent all of the weight to the front of an aldready heavy front ended set up and spun the car out of control. You should stiffen up the front suspension rather than put the stock front suspension back in.
Ok guys that is what I want.. to help me to optimise the car.. not to tell me that I am killer!!
zebra can you explain me better what are front cross ply tyres? I search it a little and I read that it is very important to run theese tires with slicks.. but I don't have slicks... I have Mickey Thompson ET Streets... They are like slicks.. they haven't metalic fibres for sidewall..
[WLDCRD]
If the S2000 continue the race she didn't have any problem.. I didn't touch her!
My front bumper hasn't any scratches! So how I touch her?
S2000 driver is a girl!!!! And we are in the same drag team :| :|
9krpm
Yes you are right!
If I leave it earlier it would be ok..
But I looose the car control because of the bumps of the street.
So you think that it is ok to have front stiff coilovers...
I also don't have front anti sway bar!! As I read at usa drag forums in every rwd they put off the antisway bar! Is it ok?
7.5 psi is very low?
The previous run was again with 7.5psi and was ok.. at the previous run I did the 11.2!
Maybe the tire pressure was less because I didn't check the tyre pressure before the run and it was night.. 7.5 was after hours that was the sun up! I protected both tires from the sun with boxes to don't have different pressures in the tires!
if some people read some things before posting they may be a little better informed
Mickey Thompson ET Street Radial Drag Tires yes Radial
http://www.jegs.com/p/Mickey-Thompson/Mick...753925/10002/-1
when i first watched the vids i though they were slicks without front runners and thought that was recipe for trouble but then read in the greeces13 sig and read he runs MT et's
i think parts of the Gibb River road in WA were flatter than that track
but at the end of the day thats racing you take it to the track where there is the support there is something go's wrong in this case it did
Edited by Walk510
ok then im quite sure you should be running front runners
as a friend ran these on his 32 with ran the front and said it scary at speed with those tyres
the radials are quite common on big hp street cars
[WLDCRD]
are you saying that if she went straight ahead then she would have been fine and only you would have crashed?
i agree with whats been mentioned before there is a noise at around 5 minutes and you can also see the side skirt on the honda move when theres contact. yea maybe only minor contact, but when both your cars are allready off balance you dont ned much.
you car fish tales at least 4 times before you back off and hit the brakes. why is this?
Is it just me or does the track look like a lumpy Piece of crap ? From the first video it really looks like the track is some skanky Alleyway with all the lumps and bumps in it. Certainly not safe enough for a 10 sec car
zebra
As I understand my tires aren't radials... they are et street model... not et street radials!
And as I read is bias ply! Like cross ply..!
So i need front runners? But why? I see also
.. but I cannot understand why I cannot run with front radials..
The videο looks like with my video haha!
dangerman4
I don't know what exatly is this sound.. but you can definatly see that she turn it left before I came closer.
9krpm
I said that I don't have front sway bar!
I have only the rear sway bar.. the stock!
GTR-32U
Yeah!! It was like a motocross strip :):banana:
And in theese crazy scare strip try to run also some top fuel cars and motos.. see them following haha.
Some of them don't run after his first run!
48349636225351441008953.th.jpg48349597215351441008953.th.jpgmessini3rdrace20091114.th.jpgpolykastro2ndrace200920.th.jpg
Also read hear about my tires http://mickeythompsontires.com/strip.php?item=ETStreet
Theese tires needs tubes.. but the seller told me tha tubes needs very heavy vehicles and my vehicle don't need tubes!
Greeces13 - If I were you Id start to do a little more research before racing again, have a look for some US drag racing websites.
I thought you figured out why you cant run radials on the front and cross plys on the rear...due to the fact that you lost control of the car.....radials have WAY more cornering grip that cross plys, So instead of having even grip at the front an rear of the car, you have massive front end grip and next to zero at the back...this is half the reason you spun.
As for tubes in the tyres if they are reccomended by M/T then why the hell did the guy that sold them to you tell you, you dont need them???
Is it just me or is everybody else getting the feeling that there are ZERO saftey regs over there?
You know bumps and bounces don't mix too well with a drag setup car... that is soft suspension and low pressure tyres. pointless comparing them to a rally car that is designed for it.
end of the day what was the recommended tire pressure for them tires? not 7.5psi. That's where the major mistake was had. Anyone else try to keep control of there car at high speed with practically flat tires... i hope not. There is a difference between lowering pressure to allow some sidewall flex and ensuring a flat footprint and deflating them so they don't work at all.
The second major mistake and the potentially lethal mistake for you both is directly your fault. You almost killed someone as well as yourself never mind the damage to their car. When you started to wobble all over you should have backed off immediately.
The track did look craphouse i agree but what you did could have netted the same result on any strip.
At least you did it on a strip and not the street which is why your posting to us, not like plenty of others who can't who are frontpage news.
I can tell you why. it's called a tank slapper and is caused by a number of things, the biggest of which is poor car control. basically over reacting and slow reacting. instead of making a small correction to both the throttle and the steering wheel you can see he jumps off the throttle which unsettles the car and then (too late) has a big tug of the wheel. hence the tank slapper which builds in momentum until he's into the wall.
I bet the S2000 driver wishes she was a few 1/10ths fast then she would have been out of his path of destruction... shame your accident also wrecked someone elses car whether you tagged it or not.
the reason you don't run radial tyres with ply tyres is not really to do with different levels of grip. it's because of the different construction of the tyres. bias ply or cross ply tyres have very soft sidewalls and very little lateral grip. running them with radial tyres on the front can cause problems with getting the car to run straight.
I would suggest going back to the ET street RADIALS. for some practice, then perhaps down the track go back to a bias ply or cross ply drag slick with the appropriate front runners to match. with more practice and some more experience your car control will improve and hopefully nothing like this will happen again.
ive had a few tank slappers on my bikes doin between 100-200km/h & it is frightening!
same as a skateboard when gets in a death wobbler...when this happens u hang on & hope for it to end.
I didn't touch her!
ella rrre - is your friend a good sort :D
zebra
9krpm
That video cracked me up but what you replied about the sway bar gives me the impression that you should certainly need to research more into car handling.
You don't wack a heavier engine into the front, remove the front sway bar and expect the car to be stable.
I read what you posted buddy. Without a sway bar at the front your car is even worst than having a stock or soft sway bar! I think you need to read a bit more into suspension tuning.
I wont' even ask what wheel alignment you had on the car.
Ok guys thanks for your good words for me.
Do you believe that I wanted to do it?
It was semifinal race of the championship at "Street RWD-4WD".
You will stop from the 1/8?
I continue the race as everyone would continue.
I was ok and I had the control of the car since I push the brakes. At the last cone was the end of the race... I hit the brakes 60 foots before the end because I was feel uncomfortable with my car.
But with the brakes the car starts to make drift.
In a good strip there is glue in all 1/4 mile.
In a good strip there is really good glue at the first foots so if I was in a good strip I didn't run with 7.5psi at my tires.
In a good strip there aren't bumps!!! If there aren'ts bumps my car wouldn't do like a ballerine!!
I understand that the strip is shit at my first run... and this run was the 6th!
That was my fault.... that I continue to do the "stunt man".
S2000 run 26x11.5x16 I run 26x11.5x15 .... Ofcourse S2000 is more stable!
S2000 had coilovers front and rear.
I had coilovers front and stock rear... maybe this was wrong too... maybe I must run with stocks front and rear!
so winning the race is more important than your life/ the other racers life and both of your cars?????
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
