R33 clear nismo indicators
VL5spd
 Share
I think you will find is $100 per pair
Secondhand yeah around $50-$70
i mean indicators arent really a wearing item like wheels etc,
so they should really hold a decent value still
cam and anyone else if you dont get this pair and still want some lemme know
RiaZ
When you ring for prices on clear indicators do not mention you own a COMMODORE, these tricky blokes tend to rip off trevs who diss their civics etc
the price for them is ~$100 could be $105, i cannot recall.
this is for a Nismo item
now $200 will be for a Nismo item in japan and then shipped over here after the supplier and initial retailer and the smaller store retailer have all made their profits
i would be interested to know who quoted you $200 for a pair though
are they like a new form of clear steel of something....do they flip round to provide a shaved fender look??
FIRE BRINGER i will grab the part number for you and you can order it yourself through nissan in NZ.
ummm...the ones on those links are also flush with the panel....and not $200, and not $35 postage either.
$35 postage is quite a larf. did they send it express air mail via Beiruit or something?
if they must sell, they must sell, but I think that at $200, youve got a better chance of finding a well thought out metaphor.
:bahaha: :bahaha: :bahaha:
seriously though, i could prolly try get some cheaper ones that are under 100 bucks here in Perth
will get back to you guys later
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
