Hey guys....
I am in need of some help, my A31 ceffy has had no tail pipe for some while now as its just been sitting around in the garage,
This is mainly due to the hangers not being there.
There is nothing existing there at the moment for me to hold up the tail pipe so i was just after some ideas from ur own cefiro's.
I have a 3'' pipe with a single canon which i may get rid of and change it to dual straight pipes similar to the Dart Izumi style.
If any of u has pics or can be bothered to crawl under there and take a pic for me that would be greatly appreciated.
Also do 1 piece aftermarket R32Gtst or R33 dump+front pipes bolt up without any trouble?
Thanks guys for any information that can be shared with me.
Skyline exhausts don't fit because they are shorter wheelbase than the cefiros/laurels.
Mine has a bracket right behind the rear bumper for the exhaust hanger. I'd suggest get rid of the cannon and get the pipes on.
what about 4 door lines? 32 or 33?
actually now that I think about it, since cefiro's share 50% of parts with R31's under the bonnet, maybe their exhausts might be similar too?
4 door skylines have the same wheelbase as 2 doors. A31/C33 have a longer wheelbase (hence why you can't use skyline tailshafts).
Could try an R31? Would have to see what their exhausts look like.
A31/C33 catbacks are pretty straight, they only have 1 30deg set in them. (Not like skyline/silvia exhausts have multiple 90deg bends)
What about just the section between the turbo and the cat?? (the dump and front pipe)
is that part roughly similar to R32 or 33?
From cat back i will get custom made as it has only 1 slight bend and is fairly easy to make by the looks of it, just want to know if the dump and front pipe will fit up alright.
Thanks Daisu for info on the hanger.... you wouldnt happen to have any pics of it?
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
