Profec B Spec2 On Rb26
Hey guys.
Recently installed a ProfecB spec2 on the 26 and no matter how i tune it i cant get rid of the spiking.
I took the pressure source from the original nipple at the back of the plenum, to the solenoid mounted by the brake booster, and then to the solid line that goes around the back of the engine to the actuators. This was the shortest possible run i could of gotten.
The source for the unit is taken from the nipple that goes to the oem boost gauge.
If seen a few ppl still get spike using the same said controller on the 26.
My question is.....
Has anyone tried taking a pressure source from the pipe that comes directly off the turbos and mounting the solenoid on the turbo side of the engine thus keeping the run of the hoses as short as possible?!?
My settings are:
LO boost- 12 psi
Gain- 5% (lowest)
Start Gain -8 psi
Warning - 14 psi
Limiter - 15%
HI boost- 14 psi
Gain -5% (lowest)
Start Gain - 9 psi
Warning - 15psi
Limiter - 15%
Stock turbos, 3" no cat exhaust.
As u can see the gain is on the lowest setting, and even though i turn down the "Start boost" setting it still spikes, so i dont think there is anything i can do again in terms of tuning the controller.
Thanks.
on low boost set at 12ish psi it would spike to about 13-13.5 psi on gear changes
on high boost set at 14ish psi it would spike to about 15-15.5 psi on gear changes
Boost does not fall off
With no % increase, wouldn't this be the same as if the controller was off?
If so it runs 8-9psi with verrry little spiking
what do you mean spiking on gear changes? Like when you snap the throttle shut it spikes?? that happens because the turbos are going flat out and when you close the throttle plates the boost backs up. No BOV is going to be able to expell that much air instantly, hence the small spike
+1. Fast moving air has a lot of momentum. Also remember that the boost will spike on the turbo side of the throttle, not the engine side so the engine wont see it and you have no problem. If it spikes in gear then different story.
There will be no pressure in the actuator lines to open the wastegates,
So as you suggested, try making the lines as short as possible and try not to have any other things running off those line, i.e boost gauge, pressure reg etc
Edit - Also try disconecting the factory boost guage line and run just the line to solenoid / wastegates as it maybe leaking
When i change the gear and stamp the throttle open, it goes up over the preset boost value for a second, and then drops back to where it supposed to be.
Sounds like your SETGAIN value is too high, what's it like rolling on in gear?
Bigger and better flowing wastegate is the best way to fix this.
With an actuator it gradually begins to open up and is fully open when boost has hit the actuators rated pressure. Problem with this is that you loose pressure inside the turbine which leads to slower spool up and less response.
All a EBC does is control a one way pneumatic pressure valve (mechanical ones work fine too :D ). This way you set the pressure for the valve to open not the actuator (must obviously be >=as the actuator pressure). When the pressure reaches the valves release threshold it flies open instantly and immediately opens the wastegate when it hits the actuator.
If the wastegate is too small/crap flow there is the potential for the turbo to not rid enough gas quick enough and a short spike in boost as it all tries to run through the same door.
True fix is a larger more flowing wastegate. easy. but really 1-1.5psi spike is nothing i wouldn't worry about it.
That being said as others have mentioned it is also important that there is no restriction/loss of pressure to the actuator.
Guys, by the sounds of it it doesn't happen with the ebc turned off so I don't think it has anything to do with the mechanical setup.
To me, it sounds like poor ebc setup.
I run two of these ebc's with no dramas but if they aren't set up correctly then it can be very discouraging.
Basically, you use the SETGAIN value to bring the boost on earlier. Each individual (mechanical) setup will determine how close you can have your SETGAIN value to your SET value (target boost). For example, my skyline with underturbo'd RB30DET (25 turbo so comes on boost really hard and fast) has a fair difference between the SET and SETGAIN values. My stagea with a stock neo engine and hiflow'd turbo is much lazier coming on boost so I am able to bring the SETGAIN value up closer to the SET value.
Read the manual, the GAIN value can be used to smooth out spiking OR tapering.
First step, is back off the SETGAIN value (even back it off completely) and see if it still spikes after changes.
Like I said in my previous post, the GAIN setting can be used to fix boost SPIKES or tapering. Read the bloody manual.
Start by increasing the GAIN 2 points at a time until instead of "spiking" it goes to that boost level and holds there (reduce your SET value some as both SET and GAIN affect overall boost).
What you will effectively be doing is using the GAIN function to bring the boost curve up level with the spike so it is no longer a "spike".
I don't know how much clearer I can make it.
i've had great success with the profec B IIs. I've had a few of them. ran one on my old GTR set-up 5 years ago and it was good, ran one on the GTR I had built in japan with HKS turbos, cams, built motor etc. and it worked well too. and am running one on the new set-up too. in fact it seemed to work better than the profec E-01 in my silvia which was $1000 when new!
this is the kind of boost curve you should be aiming for.
Quote from the manual...
"When boost spike occurs,lower the GAIN adjustment 2 increments at a time until it stabilizes."
and
"Adjusting the START BOOST too close to the SET boost pressure,it will cause boost spike"
So yes i can read AND follow instructions
Don't know which part in the manual u saw to raise gain 2 points at a time to get rid of spike :)
I remember reading some where u too also had some spiking on gear changes?!?
Curve looks sweet, but that is from low rpm in 4th i assume? If i do the same on the street i do not get any spike.... only on high rpm gear changes other wise it's smooth to redline.
with small turbos that ramp onto boost very hard you will occasionally have trouble controlling them as they ramp up. if you are at boost producing rpm. say 4500. at part throttle. and you stamp on it. they turbos spool up to target boost faster than the solenoid can bypass enough air to stabilise the wastegate. it should not be a big spike but yes you can get a small spike under conditions like that. it's not a big deal if it's only 1psi or so which is all it should be. you really need to replicate it on the dyno with proper logging of the boost curve. as sometimes the controller might beep or display a high peak that it's hitting for a nano-second as it swings into action to stabilise your boost. it can be such a brief occurrence that it's not worth worrying about.
This exactly what mine does also.
Stamp on the throttle through the gears and it'll spike up to 2.5psi over the set value as it quickly boosts up, but its there for like a half second then it drops back and holds perfect.
Slowly boost up under load in a higher gear and it holds boost dead still with out spikes.
As far as I can see it's exactly a beer baron explained and nothing to worry about.
 Share
    • Well.... yes and perhaps no. It depends on what you mean by "spool". For most of us, the point that we would describe as where the turbo is "spooling" is the point where the wheel speed gets high enough for it to start making some boost. This is coincidentally around about the point where it starts making noise - hence the "spooling" sound. If that is what you mean, then no - the wastegate should still be shut at this point. The boost will still be way below the point where it should start opening. If, on the other hand, you mean "spool" as "reach full boost", then yes. At the point where the boost has reached target, then boost control has already started. The wastegate is already open, and has been for some time. Some short time, definitely, but still, some time. If you have no boost controller - just the wastegate actuator connected to the boost source, then you have a mechanical system working as a pressure balance. There is pressure on one side of the wastegate actuator's diaphragm from the spring, and pressure on the other side coming from the boost measurement location (the "source"). This is not a digital thing. The wastegate does not stay shut until the boost pressure reaches the spring "pressure". The spring will start to compress as soon as you start to apply any pressure onto it. This can be controlled somewhat by adding pre-load into the spring, but you cannot add enough preload to make it into a digital switch behaviour. The wastegate will crack open and start to leak exhaust out (and therefore not though the turbine) well before you reach the target boost pressure. Electronic (and some mechanical/pneumatic) boost controllers will act to prevent the boost source applying pressure to the actuator until just before you reach target boost, thus preventing the wastegate from creeping open. And some boost controllers will apply boost pressure on the spring side to further push it shut. And this can be be necessary because the exhaust pressure in the manifold also pushes on the wastegate valve and tries to open it and you cab get it leaking even without it being connected to the boost source.
    • A stand alone boost controller will not give you the control you need, unlike a modern ECU. Your boost will always naturally target the wastegate's opening pressure first, your controller then will allow you to add more boost as required.
    • I recently discovered that I could not remove the outer bolt on one of my rear UCAs. Looked like it was seized to the crush tube. It wasn't all that long since I had last had that arm out (I dunno exactly, but certainly <2 yrs), so I was a bit surprised. I thought I had stock bushes in the rear knuckles, so I ordered some new PU bushes and resigned myself to having to do some dismantlery....and some butchery. It was clear that the seized bush was going to need to have the bolt cut out of it and then possibly some more brutality after that. Upon getting the 3x arms on each side disconnected from the knuckles (with the exception of the seized one, of course), I discovered that I had in fact put PU bushes into the knuckles when I did the subframe conversion about 12-13 years ago. So, I say "Oh, good, I might not have to swap any of these others out". We set to work butchering the bolt out of the seized arm. Stainless blade in a big-arse Milwaukee recipro made short work of it, and also damaged the arm, which added a welding and grinding and painting step to the whole exercise. During the butchery it became clear that the bolt was not just seized but bent. Head scratching ensued, as it is hard to understand how that bolt could get bent. I did suffer a broken (stock) toe control arm on that side a few months ago, and drove some miles with some significant rear wheel self steer and lack of control, which probably was the cause. But it's still hard to understand how it would bend that bolt, rather than just bend the arm. But here's the start of the real discoveries. The crush tube was rusty as all shit. I mean seriously rusty. A little on the inside, contributing to the tube seizing to the bolt (along with the bend). But the outside had at least 2-3mm of compressed flaky iron oxide jammed in between the parent metal and the PU bush. This one was brutalised and still took some effort to get the PU off the crush tube. So I thought I'd inspect the others more closely. The one on the tension rod adjacent the bent one was first. I had to use a 2-jaw puller to get the crush tube out, and it took some effort. It came out looking like the first one. All 6 of them were the same, except for one that looked not too bad. Had some corrosion on it, but was mostly OK. There was also a significant amount of corrosion on the inner surfaces of the knuckles. They took some convincing with pointy tools to let go their grip on the inside of the holes they were in. There was no sign of the original (SuperPro) lube anywhere. I and my bro-in-law have never seen any crush tube end up looking like this. It was seriously like the car has spent time putting boats into the water at the boat ramp. So, it seems like the PU might have been bonded to the steel on both sides, which would have to make them work more like stock rubber bushes (where arm deflection results in twist inside the rubber). Despite this, I have never had cause to believe that they were so tightly bound up. The suspension moved up and down much as you'd expect. The car never made any noises in those bushes that would have led me to believe there was a problem. Maybe the rusty interfaces actually were "sliding". Anyway, lesson learnt. Even quiet, non-troublesome PU bushes should be inspected every now and then!
    • the boost controller allows you to adjust the opening of the wastegate (which only has one preset spring) I'm going to see how it acts on it
    • I studied the principle of wastegate to begin with. so if I understood correctly. the moment when the turbo "spool" is where the boost control begins. When the target level of "psi" is reached the wastegate opens to regulate the exhaust pressure passing through the turbo and thus control its speed and the rate of boost
