You do realise ATS/carbonetic clutches are what Xtreme carbons are ? I run a triple carbon with 1350kg clamp load and 6kg flwheel in my R33 GTR. I kid you not, you would think it is a single plate it's so progressive. Still hooks up awesome too. Get one, you won't be disappointed. Don't believe they won't work cold either. They have been tested to 1000Nm at 70 deg and 1400+Nm at 250 deg. 1500hp rated and driveable ! Absolutely astonishing how a clutch can be so friendly to use but absolutely won't slip too. Got an OS giken R3C in my R32 GTR so I know what a viscious clutch is like. I'm serious - the extreme cermaic single plate was harder to drive than the triple. Every GTR should have a ATS/carbonetics/xtreme triple. Circuit/drag/street - Just amazing !
So do you have the Xtreme one or the ATS one?
Cheers,
Its the same clutch mate. I bought it from xtreme, but is made by ATS. Has ATS on clutch and all instructions are the ATS carbonetics ones. That's what I'm saying, xtreme one IS the ATS one.
So if you dont mind me asking, how much did you get it for? Did you get it from Xtreme directly?
Cheers,
Yeah got it direct as my old man's workshop has an account (need an account to buy direct) with Adelaide clutch. The triple carbon was around $2800 trade. That includes full push conversion kit, which is all the genuine nissan stuff - Slave cylinder, gearbox front cover, fork ect. I think the retail is around $3200 - $3500. They are all push clutches though - they don't make pull ones (they don't mention this on the site). Push ones are better anyway though as they are easier to fit, and gives you much more clutch options for GTRs. Not worth going for a twin as the price difference is only a couple of hunderd bucks. I would've went one in the 32 but wasn't convinced on the carbons at that stage and needed a clutch I knew would launch hard repeatedly with over 500+ kw at the wheels. Wish I had've now as the OS giken R3C needs some learning - it's not really a street clutch and would be terrible for a daily driver.
  • 9 years later...
  • 3 weeks later...
No comparison between the two. I'm still running the same 2 ATS carbon triples in my GTRs. No clutch can touch them - none. Ceramic is just shit. Carbon expensive, but worth it. Just replaced my 2 floating discs inside the R32 triple ATS with carbon coated metal floating discs. All 3 existing carbon friction discs were barely worn.
Just to clarify Carbon clutches are generally carbon friction plates against metallic floating discs and metallic pressure plate. I bought these clutches nearly 10 years ago so the price has increased a bit now from then to around $4000ish.
Just to show how far ATS has come now, the ultimate in clutches, ATS do a full carbon/carbon clutch now - 3 month waiting time to be built in single to triple. I think they start at $7000 US (not a typo) but have under 0.1mm wear after 300 launches !
Long story short, GTRs up to 1000 engine hp really only need a ATS carbon twin for about $3k as the triples are rated to 1400hp (overkill) and drive nearly like a stock clutch. Just amazing, highly recommended.
  • 1 year later...
Hi, I have the ATS triple, as you say, drives great
just wondering , when I back out cold it grabs a little and feels like the car has the handbrake half on, go into first and feels the same for a moment. After that perfect, usually drive 100klm ish every  Sunday no problems with all sorts of driving ?‍♂️
I am not worried about it, been like this for a long time, just wondering if anyone one else has had this experience
you mentioned the OS Giken , when I bought my 34gtr it had the OS Giken quad in it , had to drive it for the first time in peak hour traffic on Pendant Hills Rd , that was an experience ?
Hi Peter. It does not sound normal. Is yours a spec 1 or 2 and pull or push ? As mentioned I run these ATS spec 1 1350kg / 6kg flywheel push triples in both the 32 and 33 now (got rid of the R3C years ago, my first post in this thread is from 2009 when I first started running them) and I definitely do not experience what you have mentioned. If it doesn't bother you or cause any dramas great, but the next time your box is out it would pay just to check all the specs of everything inside the clutch.
I actually pulled the 32 triple down last year for inspection while a new engine and box was being built, and was still pretty much like new with about 0.2mm total wear across all plates combined, and all plates still dead flat with less than 0.05mm runout on the metal floating discs.
That said, while it was apart I decided to upgrade the metal floating discs and pressure plate to the carbon coated versions (note: they are triple the price of the original ones), which raise the torque and temp handling substantially. The ATS carbon clutches don't appear to be available spec'ed like this when you buy them new, but noticed it in their parts catalogue so I thought I'd try it out. Only difference I noticed is it is a little bit more grabby / bitety from cold, which I was surprised with as now it is essentially carbon on carbon with the plates. Should give them a go if you ever have to pull the clutch out.
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
