Ive searched high and low on these forums and read up on this problem but it hasnt helped me.
My airbag light is flashing and i cant turn it off. i tried the interior light switch trick and the light went from flashing every second or so to one long flash then 2 short flashes.
Any ideas?
https://www.sau.com.au/forums/topic/278730-airbag-light-flashing/
yeah i hAd a flat battery one time, then air bag light came on, tried that door light switch thing and now mine is sorta delayed flashes instead of fast ones, i eventually given up and just ignore it. unless anyone knows how to fix it?
p.s..does this mean if i crash airbags wont work???
taking the bulb out may get rid of the problem but it wont fix the cause :thumbsup: the airbag is a safety item and if there is a fault in the system it could cause the airbag not to go off in an accident or possibly worse just go off without warning, either way i would suggest you get it looked at, just my 2 cents worth anyways
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
