A mate of mine today went to get RWC for his car and he failed because there was like a tiney amount of rust on the front and rear passenger door. Were talking like 5c coin sizes. I was just wondering why does rust fail the RWC, I dont see how it effects the vehicle on the Road and when I did my RWC a couple of days ago I dont recall seing a box that said anything about rust.
So any info would be great on this because I'm also looking at buying another car and the guy said it has some minor rust.
Cheers,
Aleks
https://www.sau.com.au/forums/topic/278740-failed-rwc-because-of-rust-really/
yeah rust is a nono
but some people misinterprite the rules regarding rust and compliance ti rwc standards
afaik only structural rust or rust holes in a panel are a fail bubbles are not
as i said thats what ive always been told and ive never had a problem adhering to that
yeah rust is a nono
Hmm, I think i might stear clear from the vehicle then I don't want to start fixing crap thats rusted lol.
There is a way though... if he doesnt want to properly fix the rust right now just use bog and spray paint it so no visible rust = RWC
Happened to me ages ago and was told as long as there's no visible rust should be fine for RWC
LOL, how stupid is that seriously, the rules in this state are retarded.
Your last three threads in the QLD section...
Just putting it out there... Soz but I cant hold it in anymore...
(edit) change that to last four threads...
Whats wrong with them, I need information. And they are not all related. I know I asked for a RWC and now the rust issue, but its not related its for two separate vehicles. 1 car I have now (thats the one that went for the RWC), The other is owned by a friend and then when I went to look at another car to buy as project it had some rust on it, and my mate was telling me that his one failed the road worthy because it had rust, so I just wanted to check what the rules are around that area. The car I was looking at wasn't registered so I presumed it would need to be towed, but apparently you can get a on day rego.
So tell me o wise one what is so retarded about my posts? We cant all be smart like you COL and build 300KW monsters and know everything about everything and every rule and towing company in QLD. So sorry if my posts were retarded to you.
Its ok dude, im just having a lend...
PS> You dont have to be smart to build a 300kw skyline, just read these forums...
I was wondering when someone was going to put my posts together and say its dodgy :D
It had crossed my mind numerous times :D
There we go now you know so no more need for speculation lol One was for my vehicle, one was for a mates and the other one was for a car I was looking at but didn't end up getting because it was in shit whole condition lol.
+1 I just bit my tongue and moved on :)
I wouldn't call your threads retarded .....just amusing
OH well this is the only forum I know where I can get general information about laws and other car stuff thats specific to QLD even though I sold my skyline about 2 years ago :P
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
