  • Replies 74
Posted Images
I guess the surprise inside was why the engine was $3500 USD :P ?
"I got everything for 3500 bucks, which, if you know anything about pricing of the GT-R engine, that's a steal."
Haha, well now you can get a GTR engine for 3500 all day long. I bought one 5 years ago for a 240sx for almost 7000 dollars. insane.
That said, I pulled the engine from a running GTR stateside from a guy who was a friend of mine. In fact when I told the guy I bought it from (3 years later) that it was messed up, he gave me an RB30 longblock, but since it won't fit in my my BMW, I'm saving it for another project...
love it mate cant wait to see the finished car
Just out of interest what are specs of your rims? I have the same rims on my GTST but they look like some cool offsets where did you get them?
why is the manifold runners soooo long and soooooo large in diameter for such a small turbo?
also it could be a good idea to do some proper heat shielding of the exhaust beside the box or u could run into box problems with overheating oil
It was the shortest runner length I could use and maintain equal length. Since the turbo sat so far forward, runner number 6 basically dictated overall length.
The diameter isn't that large, really: It's a 1.5" schedule 10 manifold with a wall thickness of .109.
That makes the inside diameter 1.682", that's a flux area of 2.22 in^2
The RB26 exhaust port has a flux area of 1.60 in^2.
That's only 30% larger than port diameter. Which is on target to a decent amount of literature I have read. Shorter runners would have been better for my setup, but it's gotta be what it's gotta be...
* Runner 1: 20.790
* Runner 2: 20.861
* Runner 3: 20.794
* Runner 4: 20.759
* Runner 5: 20.801
* Runner 6: 20.786
Standard deviation: .033
Edited by ctnewman
Alot of time and effort there mate, top job so far.
May I ask why the dump going where it does?
SAFE to run it there
looks like it would foul on the steering link if it was in the 'usual' position.
Ive seen EVO drag cars with the turbo mounted behind a shield in the passengers footwell...so i dont see it causing an issue.
Edited by DiRTgarage
Got the transmission in today. Not as easy as I expected, the little bump where the starter goes contacted the firewall. I had previously only installed the trans with no clutch, so it could slide nearly straight up. This was not the case now, but it went in without TOO much effort. Starter went in too.
I also permanently mounted the brake booster as well as the clutch/brake pedal assembly.
Lastly I made up the last piece of the fuel feed line, had to order a few parts from summit to finish up the return, but I know where I am going to mount the regulator now...
I feel it's little stuff like how you mount the lines that really makes a build good... I hate zipties and loose hoses.
not sure if you already explain but why a bmw?
still, nice build and interesting placement of the custom exhaust. in summer its going to get hot in the drivers seat. also, dont you worry about the exhaust heating the transmission?
with the engine colour at first i was ;) but then :P
good to see different types of car builds out there instead of the same old cars all the time!
you might though need some extra ventilation on hot track days..! and also, is your bonnet going to close properly?
love this build, love the engine, love the wheels.. its a + from another member!
Thanks!
The hood does close:
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
