I was changing plugs and oil today, not too difficult, untill I found plug 6 full of oil, seeping from the rocker cover.
So off comes the intake plenum, plugs and wires everywhere. Got the cover off and I cant find anything wrong. I know there has been a drip onto the turbo occasionally, but the plug hole was full to the brim, there must be something wrong. Anyone else seen this one?
I used a sealant on everything and got it all together, now the engine light is on, probably from disconecting the throttle body? The car seems to drive ok with no obvious leaks.
Hopefully the tuner can organise a reset for me on tuesday when the emanage goes in.
https://www.sau.com.au/forums/topic/278768-oil-leak-onto-turbo/
Sorry, the missus wont let me near the camera when Im that dirty.
I cant find any leak, but the rear plug on the passenger side was swimming in oil, this was then running down the rocker cover, dripping onto the turbo ex manifold. Very slow leak but over time filled the hole.
I cant see how the seal around the plug tube is removed, are there any pictures in fast?
  • 3 weeks later...
Hi Scott
I came across this info today about the rocker cover seals leaking into the spark plug wells. Thought this sounded like your problem.
http://g35driver.com/forums/g35-sedan-v35-...arranty-up.html
Cheers
Andy
Hi Scott
Cheers
Andy
Yep. That would be it.
Sounds like a VQ issue.
I put anerobic gasket sealent around the seal and tube, should do the job. Im not spending the $300 or more. We should all check the plugs, this problem will be worse on m35 due to the turbo heat.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
