Im selling a cheap Inverter type TIG welder. The machine is DC only, it will not weld alloy (AC welding)
Its a china brand and only 6 months old. Comes with a good quality torch attatchment, ground cable and power lead.
You will need to buy Tungstens to suit your material, collet and a flow meter.
The unit is capable of 200amp welding and ive run it for long periods without any issues at 90-100amp. So the duty cycle is decent enough to weld up cages and general jobs.
Im selling it as I have upgraded to a new AC/DC machine and this is now sitting around so someone may as well get some use from it.
Works perfectly and can give a demonstration of its weld quality before purchase if you want.
Asking $200 pick up but may be slightly negotiable
Located in sydney.
Edited by Risking
https://www.sau.com.au/forums/topic/278788-tig-welder/
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue.
    • Anything above ~9.5V is acceptable. The higher the better, but it will almost always drop to at least 10.5V, if not lower, even with a new big battery and everything else being good. 9.76 is not a concern. If it goes below 9, you'd be sure that there's a problem with either the battery or the connections.
    • It's new almost. Under a year old i think and I've tested it twice at supercheap
    • Glue the head from a Pez dispenser on it. Goofy, or Winnie the Pooh, so something.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
