On the Gloria, the front tyres are worn to the belt on the very inside if the tyres - only about like 2cm - it's like someone has filed the corner of the tyre on the inside.
The rest of the tyres are fine - good even - it's only the very far inside corner of the tyre.
The rears are fine.
Yes the car has been lowered.
Originally posted by Silver-Arrowz
Not sure what the suspension on the Gloria is or like but when lowering some cars cause excessive camber. Either that or excessive toe out, I think?
yeah, probably a toe problem, get a wheel alingnment. I think inside wear is toe in tho, not toe out. Either way you should be looking for 0 toe.
Camber, Toe In, Tow Out - ya da ya da - I have know idea what all this stuff is -
I know that camber is when the wheels look really phat cause they are fully on an angle bro - so you can go round corners faster. :D:)
I reckon it has something to do with the fact that the car is lowered - I sketched it out , with the force lines and stuff.
I'll take it to a suspension place after I get rego - Not sure that a wheel alignment will fix this - the wear is fully severe. They will prolly ping me for the tyres when it goes in for a blury tomorrow - but that's cool, I'll get some new tyres and then take it to a suspension place.
Unless, the wheels and tyres are off another car that had a problem - maybe there is nothing wrong - Anyway I'll tak it to the experts.
I thought there might be an easy/quick way to tell if there was something wrong -
When I looked underneath there wasn't anything broken !
Cheers for the help !
taken from whiteline page
Toe is the difference in distance between the front and rear of the tyres. Historically front toe was the only thing that could be modified as rear wheel drive vehicles using a rigid axle had fixed rear toe, usually neutral. Many modern front wheel drives have rear toe adjustment as standard which is critical to their handling.
Current VT Commodores have an independent rear suspension design that has substantial dynamic toe change requiring after market solutions to correct. Whiteline IRS Camber/Toe adjusting kit is designed to around this problem. Essential when lowering. (See IRS for more details)
Excessive amounts of either will adversely effect tyre wear.
Excessive toe-in makes the car unresponsive and doughy.
Excessive toe-out makes the car nervous and lacking in directional stability.
Minor values are useful for improving turn-in, steering response and masking torque steer.
Excessive wear on the inside is probably 1 of 3 things Brendan:
1. Excessive negative camber. i.e. The bottom of the wheel sits out further than the top of the wheel. (the "phat cause they are fully on an angle bro " of which you speak :P ) or,
2. Excessive toe out. i.e. the front of the wheels are further away from the centreline of the car than the rear of the wheels. They "point out" like each wheel is turning in a different direction. However, the amount of toe out required to do this would make the car very twitchy.
3. The tyres were worn on the outside and swapped over on the rims to hide the problem.
I'd go with 3 or 1.
:D
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
