R32 Gtr Heavİly Modified [vic]
1989 R32 GTR including new paint engine build and gearbox build up 21,XXX k's since full rebuilt
The list:
Forged Engine
CP Pistons
JUN Oil Pump
SARD 700cc Injectors
N1 Water Pump
Oil Drain Added To The Rear Off The Head Back To The Sump
TOMIE Oil Feed Restrictors
TOMIE Sump Baffles
HKS Adjustable Cam Gears
Apexi Cams
ACL Race bearing Throughout
ARP Mains + Head Studs
TOMIE Head Gasket
HKS Timing Belt
All New Hoses And Gaskets
Also In The Bay
Oil Relocation Kit + Cooler
After Market Radiator,
After Market Cooler Piping And Radiator Hoses,
Nismo Airflow Meters,
K&N Panel Filter In Standard Airbox
New O2 Sensors
Huge 600x300x120mm Intercooler,
Garret -5s Capable Of 430+ rwkw
Gearbox Was Completely Reconditioned
Including Syncros 2/3/4/5
3/4
Every Seal And Bearing Has Been Replaced
RECENT RETUNE USING NISSTUNE 03/06/09
341rwkw on 18 psi now, on a safe tune
DYNO PAPERS PROVIDED
Other Parts Changed Out:
New Coil Packs
The Altessa Pump Changed
Hicas Lock Bar Added (Rear Powersteering Pump Impeller Taken Out To Completely Disable It But Still Keeping The Cooler)
Bilsteine Coilovers All Round.,
Very Good Condition R32 GTR Wheels
D-speed Clear Indicators,
Front + Rear Sway Bars Also One In The Middle Of The Car.
Torque Split Controller Added With a 2wd/4wd Switch (In The Console)
Boost Controller Hidden In Fuse Box.
I Am Selling My R32 GTR Because I Need 2 Cars For Myself And For My Brother...
PRICE 24k ONO AND WILL CONSIDER SWAPS
There Is 9 Months Rego On This Car And Will Come With RWC...
Cheers, Taner 0403172796
Edited by gtrkid123
 Share
    • Another complicated thing is to run Z32 alloy hubs which have wheel speed sensors for ABS. You need different tie rod end, and you need new bearings on the upright etc. I did that as part of a major refresh when my front kingpin bearing flogged out., Alloy was a little lighter, runs a bigger bearing , gives a few extra mm in wheelbase as it moves the wheel forward in the arch (cant run crazy but can still get 8ish comfortably).   All in all glad I did it but was a head fark as tried it once and abandoned it the first time. sav man swung his spanners at it and got it working so using his guidance on GTR/Z32 tie rod ends etc and the required mismatch of parts was able to make it work.  Probably a 2k upgrade all said and done :(   I think the best bet is just look around your front wheel and see what you can pick up rotationally. You see old Escorts, E30s etc all get very creative with front uprights and the humble old angled alloy bracket.
    • Big claims here.  Any links up on the website ?
    • If your HP goal is reasonable and you are not drifting. Buy a new R34 box.  If the above is not true, buy a wrecked R33 box and put a gearset in it.  CD09 are not as strong as you think and the cost of / mess around of the conversion puts you in gearset territory.    Also the deal above is awesome,, get that
    • Just got back from a little hands-on with a G58 Baron....I was thinking about this... ..best I can figure it, that pinny was tail-ended ...I didn't really think about the wiring, because all that mattered was the tank and pump cradle (I think I mentioned the pump itself I couldn't vouch for)...which didn't matter, as you said you'd be replacing the pump anyway.... ...'for some reason'....and I imagine this is the panel shop's doing... they've replaced the cradle wiring with a metre of 7-core trailer loom, and attached the loom plug (from a different car) to that. The actual cable run from the top of the pump cradle, to fuel pump harness end in boot, is maybe 60cm in length...so I've no idea why they did this... ....the connector in the boot of the pinny, is not going to help you here...because in theory, it should still be present on your car. On top of that, because they've done what they did, we have no idea which colours of the trailer cabling, have been connected to what on the fuel pump cradle (pump +/- , shield, fuel guage/low-level senders)... ...this means, best approach is to remove the pump cradle, and re-work it now ...not later. That is, if you were going to replace the pump, do it, replace the soft lines at the same time...and sort the wiring out (replace that trailer cable with the wiring loom off your old cradle)...
    • Well, maybe not. The main feature of Chinese manufacture seems to be incredibly variable quality, coupled with an apparent willingness to find a way to see even the stuff that fails QC. So the military could still take the cream of the production run and somehow sell the "sellable but not really useable" stuff to the stupid round eyes on the other side of the world.
