Hey guys,
Some AWESOME news!
Ive worked my magic with our insurance company, long story short the costs for this event have been reduced.
What does that mean for you?
The Texi entry fee has been changed, by more than HALF! Thats right, HALF!
The day now is $40 per driver
So you've got to ask yourself; How can you go wrong for $40???
Is your entry form in yet?.........If not - enter, NOW!
Form attached and general event thread is linked below
Cheers
-Steve
http://www.skylinesaustralia.com/forums/in...t&p=4604816
Texi_29th_Aug_ENTRY_FORM.pdf
https://www.sau.com.au/forums/topic/278861-texikhana-skids-on-sunday-40-entry/
Borrow a car from your parents/sister/brother/best mate/girlfriend or whoever!!! This is the kind of event where you DON'T need to have heaps of power to get around the course quickly, as it's all about being able to maneouvre around the cones as efficiently as possible. But more than that, just get out there and HAVE SOME FUN!
In.
Andy also said I can use his 33 for one run :banana: but im affraid that will bring back memories...
:banana: Now thats more like it!!!
Come on kiddies, dont be shy this event is going to be pure awesomeness x11ty!!!
If you arent book in then :banana:
DO IT!! :)
This is the kind of event that you'd bring along your vid-cam to! :)
If you don't have one, get a loan of one! :yes:
The footage alone is worth more than the 40 bucks! :yes:
Ever seen an advertising billboard goin' sideways across your front windscreen? :D
And if your handycam isn't fixed to your car, it'd be worth having a trusty SAUer (or shotgun) film you doin' it :D
Extinguishers!!!!!!
answer me!
Needs to be installed and not loose..... some options are to use a pre existing bolt point, or remove passanger seat and use some mounting points from that...
does it have to be bolted?
Like I can cable tie it yeah?
Bolted = Yes
Cable Tied = I'll let an official organiser / scrutineer answer that.
Any motorsport i partake in, cable ties wouldnt suffice.
edit - I read the entry form
whats the go with extinguisher? I dont really want to drill holes in the golf to mount.
Come on Jase you've been around long enough to know :D
Must be secured, if the scruitineer gives it a shake and it moves you're not going to pass. Also the extinguisher has to easily accessible from the drivers seat, so if you "were" to do the cable ties you'll have to use a shitload of them and make sure none of them interfere with the extinguisher coming out in a hurry. In saying that though, I wont accept cable ties on the day and scruitineers will be told the same.
I know a car like your wont have a problem/need for the extinguisher, but insurance is a PITA and we have to do what they say :D
The best way to do it is like this (i dont want to drill in the supra so ive done this using the existing bolts);
Yeah I do know, but I wanted to know the scruitineers/your opinion on how it should be attached......in non permanent ways as opposed to someone who wants to have it permanent or didnt mind making holes.
Thats the answer I was after.
I'll have a look into how hard that will be. because I really dont wanna be drilling holes and shit.
I'll give it a go.
Good stuff :P
Note in my setup there's no perm holes, the screws into the wood dont go through the wood to the carpet, once i dont need it i just undo the bolts on the seat rails, slide the brakets out then put the seat rail bolts back in - no one will ever know
    • Had another look at the car and I noticed the fuel pump isn't priming on ignition. I'd taken out the pump from the boot to siphon out the old fuel, so maybe I've knocked something loose or broken a wire putting things back together. Will go back with a multimeter and try to work out what's stuffed. Kinda hoping it's the pump itself thats gone so I can upgrade it
    • Yeah agreed, you can't assume that shop are they only people who ever had to work on it. It was just a guess on the mods based on how things were done back then. You can check the Air Flow Meters by the part number on their tags, they are likely either Z32 or Nismo ones (both read about the same but the Z32 one is a little larger while nismo is stock size but supports the higher airflow like a Z32). And yes, all that would get you to 450hp / 340kw To tell what is happening with the turbos, you want a photo of the tag on the core, that will say what it was made out of  (they can retain the front and rear covers to make the plumbing easier)
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
