R34 GTT Bomex front bar----i did use this for track days but not anymore needs TLC
$50
R34 standard white bonnet---slight dint near passenger side headlight nothing a got panel beater couldn't pop out see photo's
$200
R34 OEM style carbon fibre bonnet --- bonnet lifted while driving (not me the old owner of the bonnet) not too damaged again used this for track days etc not too badly damaged just want it gone...has bonnet pin latches but ill have to find the pins
$200
WORK EUROLINE wheels 18X8 unknown offset just a pair EX_DRIFT WHEELS no buckles just gutter rash...no tyres ive got the centre caps too need TLC also
$250
CONTINENTAL CONTACT SPORT X2 ------235/45 R17 97W still roadworthy just got too many tyres at home for skids
$30
BRIDGESTONE RE050 A ---- 215/45 R18 89W still roadworthy just got too many tyres at home to do skids on --
$40
R33 factory rear strut brace--- dosnt fit R34 found out the hard way
$100
19" wheels a set of 4 one has gutter damage still holds air 8" wide unknown offset front tyres are just roadworthy the rears are still good!
235/35R19 been sitting around for ages! want them goneskies
$300
R33 JIC coilovers NEED REBUILD was going to get them rebuild to a custom level never ended up doing it .....2 are leaking the other two are ok unsure what too been that long want to sell them as a full set
$150
R34 GTT rear wheel bearings and hubs suit..i upgraded to GTR rear end no longer need prefect condition replaced the bearing about 5000kms the changed the whole rear set up...prefect for a 5 stud conversion
CONTACT ME VIA SMS 0401035221 or PM
TOM
Edited by tommygr34
Hi mate, very interested in some stuffs! Plz send me close pics of these three:
$50
$200
$200
Plz help me with this ASAP! Plz send me pics to my email [email protected], or contact me on 0433566067
Cheers
Edited by Obelisk
19" wheels
GTT rear hubs
coilovers
greddy gauges not wiring harness or sensors gauges slightly dinted ($200 OBO wont separate)
bomex bar
r34 bonnet damage
safety21 front hoops and front crossbar,,, i didn't use these for my car i just used the rear half of the cage, bolts, mounting plate everything you need just not the back half of the cage ($250)
r34 L.E.D taillights (unknown brand) good condition swap plus cash ($200 ono)
MORE PARTS COMING AND PICS!!!
  • 3 weeks later...
  • 4 months later...
 Share
    • Thank you for the heads up! Will definitely take a look!
    • Hi all,  My 1990 R32 GT-R has developed a bad knocking sound coming from the what I assume is the front differential (the reason why I assume this is when I pull the fuse for the asetta the knock disappears put it back in and it comes back and yes the transfer case and gearbox has fresh oil in it), the uni joint on the front differential side was broken bad it would have been causing massive vibrations into the pinion gear,    has anyone experienced this before? And is anyone selling a front differential Center complete with pinion and crown gear ?    For the drive shaft I can’t find any driveline workshops in SE QLD that will put a new uni joint on the front prop shaft as they are a staked uni joint no one wants to touch it 😭 does anyone have any recommendations on any workshops that can replace the uni joint ?    sorry if this has been posted before I couldn’t find anything using the search function for this exact issue  thank you  NSM32    sorry for the bad photo, yes it’s missing a bolt I took the photo while removing the shaft to take to a workshop to try and get it repaired
    • The offset of the wheel is usually stamped on the inside of the rim. So just pull the wheel off and see if it's marked as such.
    • It's very possible my measurements are wrong as I did measure with the wheel and tire still on the car. It's possible I didn't judge inner gap correctly and ended up adding width. I'm eager to buy new wheels, but I think I might be putting the cart before the horse. The best thing to do this right. I can take off the wheels off, I might even just have the tires taken off and do some proper measurements. It won't cost me much, if anything, and will save me a whole bunch of headache in the long run.
    • You are right, there are 2 ways to approach it, you can go for wheels known to fit well on the car, or measure from what you have. If you jack up the car and check the distance from the inner side of the tyre to the first obstruction (generally the control arm, or a shock) and then do the same from the outside of the tyre to the guard, that tells you how much wider you can go or what offset you can use. I'd note that 9.5 is huge on the front of a 33 gtst, if they are not scrubbing anywhere including fuil lock then don't change anything about the front width and offset.
