Need Help With Graphic!
Guest RedLineGTR
Originally posted by DRFTiN'
Hi could someone do me a favour please! :D, in the pic below could someone crop the black skyline so theres no backround, i did it but the tires look weird and stuff...thanks...(jpg format or png please)
thats a nice pic.. comeon dark...stop wasting ya time on those crappy movies that you've probably seen 10times..
