Does anyone know what sort of nut i am meant to use to attach my front bar to the body? And where i can get them from?
Just going through the process of fixing up some of the things the previous owner did, and i noticed he lost a bolt and nut from the front bar so it wobbles around and looks quite flimsy. I would use one of the other nuts as an example, but i cant get them out so i dunno what they look like.
Cheers for any help,
Martin
https://www.sau.com.au/forums/topic/278891-captive-nut/
so front bar to the guard?
cant you use a regular bolt with a lock nut?
havent pulled apart an r34 yet, so hard to know on your model specifically
Well it could work, except i cant get my hand or a tool in to where the nut goes to hold it and stop it turning, which i assume would be why they used captive nuts in the first place
https://www.sau.com.au/forums/topic/278891-captive-nut/#findComment-4714898
well - then you could use a nutsert/rivnut but that will only work of the hole in the guard is round, not square like on the 33's
best bet is to find someone wrecking a 34 and see if you can get the "nut" from the guard
https://www.sau.com.au/forums/topic/278891-captive-nut/#findComment-4715491
No one knows?
[/quote
see the attached pic for guidance
if its the really hard to get at one 1/2 way along side of bar its about $1-60 from your local Nissan dealer - there is no nut just a phillips head screw going straight into a plastic connector that is a one-way special fit into a hole in the metal part of the guard- in some cases (in my R34) the screw is angled in the connector so as to pull the bar in correct alignment as it is screwed in - to remove it should unscrew ok unless the plastic has been stripped or somone has put in a makeshift non-standard repair - your bar should be closely like the one in the pic - if necessary to try to get enough access undo the last connector (closest to wheel opening) again this is a screw straight into plastic fitting, and just pull the guard out it flexes a fair bit - the engine/underbody fairing is a bloody nuisance so you will need to loosen and try to push it aside also if possible
https://www.sau.com.au/forums/topic/278891-captive-nut/#findComment-4717270
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
