Hey im assuming this is fairly normal granted its been pretty cold?? Drips a bit of water too. It all stops once its warm?
Just dont remember my old clubsport doing it quite as much...
If it stops when warm its nothing to worry about! Mine does the same when cold.:D
https://www.sau.com.au/forums/topic/278906-r33-gts25t/#findComment-4711510
+1 to the mentioned above.....my car blows a heap of smoke when cold start and as soon as it warms up a bit then its all sweet......just try not to drive it when its really cold lol
nothing to worry about mate
https://www.sau.com.au/forums/topic/278906-r33-gts25t/#findComment-4711527
don't warm up your car in the morning. bad for your engine. wears your plugs, allows unburnt fuel to condense and drip down past your rings into your oil diluting it.
more relative to what you're talking about, if you warm it up for like three to ten minutes it will take MUCH longer to get rid of the water vapour. Doesn't hurt your engine... it's what it's designed to do. Warming up for 5 minutes is an old wives tale. or husbands. either way, it's lame and misguided.
best way to warm up your car in the morning and get rid of the water vapour is to nanna it until it reaches just under operating temperature (a safe temp is about 70-75°, suitable op temp being between 80° and 95°C).
Try it out, the lot of you. If there's one thing you can trust, it's a dude on the internet. (That dude is Doctor Karl, bitches.)
Edited by Dorigecko
https://www.sau.com.au/forums/topic/278906-r33-gts25t/#findComment-4712933
:D
https://www.sau.com.au/forums/topic/278906-r33-gts25t/#findComment-4713035
while it is a bit off topic, i am also against the letting your car sit there and idle to warm up. the main reasons being that it takes longer for a car to warm up when it's just sitting there idling, which means the car is running for longer at colder temps. the other reason being that it doesn't warm up the oil in the gearbox or diff.
another thing to take into consideration is that if you run your car for 10 mins every morning before you start driving, over a 1yr period, that is nearly 61 hours of running that your engine has done that hasn't been taken into account on your odometer, which means more than likely not taken into account on your servicing frequency. and not to mention the extra fuel you are using.
https://www.sau.com.au/forums/topic/278906-r33-gts25t/#findComment-4713470
30-60secs then I drive it. Stagea (being auto) I cruise along at 1500rpm while people behind me hurl abuse. Skyline I shifted at around 1000rpm (3L ftw :blink:) till it was out of cold start (>65deg).
Just don't load it up.
Edited by bubba
https://www.sau.com.au/forums/topic/278906-r33-gts25t/#findComment-4715420
    • I have one and it was at ~43.5PSI.
    • Put a pressure gauge on the fuel rail.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
