Hey peeps,
My standard RB25 clutch is completely fried, i mean it slips in every gear :D
Obviously i need a new clutch, so i was looking at an Exedy HD Clutch?
Can i get some opinions on different types of clutches you have in your cars and a rough pricing guide. Also where to buy from.
My RB is only lightly modded with a full exhaust, FMIC, pod, and boost - so 260-270rwhp is the max it makes. However i want a cluutch that can safely handle up to say 300-320rwhp.
Cheers for any help :D
Forgot to add, i'll be installing the clutch myself with some help from my brother :)
Edited by syfon
https://www.sau.com.au/forums/topic/278946-need-a-new-clutch/
I quite like the "Ace Clutch" (not sure who makes it) but it has a nice feel to it (IMO) and can handle some decent power. You can also happily park the car without needing to get a little right foot happy.
coventrys are the agent for either exedy or extreme clutch's
i run a exedy 5 puck in my gtr and it is fine
or if you want the best get a jim berry clutch from over east
Edited by gazza750
Slide have a great range of clutches: http://www.skylinesaustralia.com/forums/Cheapest-Clutch-Kits-Aus-t200652.html
I got my Exedy 3 puk of them. . . Believe it or not its a comfortable drive and it slams in every gear. I love it.
If your going to go for a clutch, go Exedy. You wont regret it, worth every dollar! :P
Dont use slide, use kudos motorsport... Exedy HD clutch is fine for your HP application and they are around $550 delivered. You'll have to machine your stock flywheel as well, unless you buy an exedy lightened flywheel which is what I should have done :P
Alternatively if your not comfortable installing, labour is around $450 for machined flywheel, install and genuine gearbox oil :nyaanyaa:
Edited by Dani Boi
Hey peeps,
My standard RB25 clutch is completely fried, i mean it slips in every gear :nyaanyaa:
Cheers for any help :P
Forgot to add, i'll be installing the clutch myself with some help from my brother ;)
If you want it to last and handle 320rwhp i would strongly recommend not getting an exedy single hd clutch.
Pay a bit more and get a full monty clutch from Jim Berry. I am just about to go pick mine up with it installed so i will let you know how it feels. From what ive heard it feels like stock but bites like a pit bull and will last forever.
Personally i don't like the feel of organic clutches...my brother has one in his 180sx and its kinda weird to use but its kinda cool at the same time.
I prefer being able to feel the friction point - feeling it bite
I rang CBA Malaga and they quoted $600.00 + GST for an Exedy HD Cushion Button clutch....
I can prob get it about $50.00 cheaper from CBA Malaga through someone i know so say $550.00 + GST....
Is that a reasonable price?
u can get it for around $500 or less if u get it off nissansilvia.com, or even a trader off here will have a deal that is cheaper than what u have been quoted b4. off the top of my head for the same clutch u mentioned it was about $496 + $20 postage off ns.com
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
