I once caught a thief in the act of breaking into my R33 and this is how they do it.....
1) They wedge something in between the drivers door glass and the door jam - as there is no pillar surrounding the door glass, it warps slightly and leaves a gap.
2) They stick a thin long rod down through the gap to the anti-carjack switch located on the switch panel on the driver's door to unlock the passenger door.
3) They open and enter the vehicle via the passenger door.
4) Your life comes to a complete stand-still when you return to where your Skyline once parked.
SOLUTION - Open up the door trim to access the back of the switch panel on the driver's door and disconnect that anti-carjack switch - that useless piece of crap..... See ? Nissan isnt perfect.
  • Replies 42
you can do that - or
you can make it so that when the car is turned off the switch is an instant trigger for your alarm and does not unlock the door
and while the the car is running it works as normal...(or locks both doors)
Even better, hook it up to an inverter and sending a 100000000 volts of electricity thru the bastard's body.... lol
or, even better, get an alarm system with a three point immobilizer with an on board turbo timer and no stupid remote start crap. they can only smash the window and steal all the stuff out of the car, unless you fit the siren in the cabin, making it really unpleasant to be in there...
does this apply to R34's as well ?? I have taken the door trims off more than once before but I don't recall seeing a "anti carjack switch". Is that the switch that locks/unlocks both doors when you push it? Will leaving it disconnected cause any problems with existing alarm etc ?
There should 4 switches on the drivers door handle, two for left/right windows up/down, one to isolate all functions and the last one is that switch that remotely locks and unlocks the passenger door - THAT is the switch we're referring to.
Yeah, THANKS for broadcasting to the world how to break into my car!! Good piece of anti-theft info there.
This is out of good faith due to my own personal close-call, this happened to me 3 weeks after I picked up my R33 - before I had a chance to install an alarm etc.... Im sure there are other Skyline owners on here that wouldve appreciated this advice and went straight out to do something about it.
If you have the money to drive a Skyline, then there is no excuse not having an alarm and if you have an alarm then you shouldnt have a thing to worry about..... But then again, there's always that ungrateful clown that does nothing but bitch like a woman.
if they want to just "get in" they can just smash the window ..easier and quicker too. This is where alarms and immobilisers come in handy.
Smashing windows make noise and cause attention.
On this particular day, I parked the car at Parramatta's Westfield carpark on level 5, went down stairs for not even 5 minutes, came back up and found my car door semi-opened....which I found unusual as we all know, these cars lock themselves after 60 or so seconds.....I looked inside and they got as far as unscrewing my steering column cover and my key barrel dangling....another 2 minutes and it wouldve been gone. I looked around and saw 5 lebanese kids (probably from Auburn) watching me in a hatchback all with a 'damn ! spewin !' look on their faces. I got their number plate just as they drove off.
I reported this to the cops, they came and finger printed the car and tells me that I was extremely fortunate as there has been a string of these imports stolen from that very carpark in recent weeks. Oh yeah, that number plate was stolen as expected.
So yeah, I went straight out and spent $600 on an pager alarm system the very next day.
no need really - me being me I can have the car gone in 2-3 minutes anyway without hitting that switch.
You wouldn't be the only on either. If someone wants your car they'll get it..... All you can realistically do is make it difficult for them, maybe difficult enough for the bastard to go look elsewhere
exactly. my job is to slow them down and deafen them in the process.
mind you if I was going on a car collecting spree I'd knick a tow truck first anyway.
how did you come to that conclusion of what nationality they were???
I know enough of them to tell the difference between a Leb and a Turk, not that I have a problem with either of them consider some of my best friends are Lebs and goat lovers...They were young little punks but they knew what they were doing....minimal damage to the car....They wanted to take it.
Edited by smok74
  • 1 month later...
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
