  • Replies 42
  • 1 month later...
dont know if this will be useful to anyone but heres what i did to make my car
hard to steal...
1.Deleted the door locks, LF door RF door AND boot.
2.Disconnected the the rods that control unlocking the door(from the inside)doesnt
effect the alarm at all.
3.Relocated the master switch to where the cup holder use to be(is practicly useless anyway)
also fabricated a panel for it to fit in and coloured to match the interior
4.installed a gearshift lock.(unless they tow it it aint going no where)mounts to chassis and is similar
to a steering wheel lock
and finallly...
5.installed a triple immobliser dynatron alarm (5star NZ rating)
Overkill? i think not!! :D
maybe borderline overkill...lol I clublock my car even in my driveway eventhough i have an alarm. i'd like to see what the shifter lock looks like mounted though.
Yeah, THANKS for broadcasting to the world how to break into my car!! Good piece of anti-theft info there.
your car may get nicked from the same process and then you would say why didnt someone tell me earlier how easy it was. I cut my wire years ago after someone on the forum pointed this flaw out.
from memory it was the brown wire that goes into the switch unit but double check people by doing a search maybe as this is from my dodgy memory....i take no responsibility...ha you could always re join the wire if its the wrong one..lol
Edited by (B1) MR_fanny
my alarm beeps if you are in the vicinity of my vehicle and will go off with a bump to the car or anything moving inside the car. i did spend $800 for that on top of the security from the previous owner. i think it is totally worth it and not overkill......my prestige plate was stolen and my alarm went off but they were gone before i got to car.
  • 3 weeks later...
  • 3 months later...
  • 1 month later...
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
