post-44326-1247473053_thumb.jpgpost-44326-1247473053_thumb.jpgThought I'd share this little project incase anyone else was thinking of doing it also.
The diff is a 3.9 R200 LSD originally out of a DR30. The diff centre is all I obtained initially as I was under the impression the R180 flange and halfshafts would suffice.
After having a hard long look at it once it arrived I was unsure about what I was embarking on.
A phone call to Stewart Wilkinsons, Datsport and a friend who races and builds Z cars confirmed the obvious.
The R180 has a single retaining bolt to hold the halfshaft inside the diff.
The R200 has a flange (seperate item to the halfshaft) that is held in place with the use of a clip,when the flange is pushed into the diff it locks itself into a purpose made groove.
As you can see in the pics the half shafts are totally different . Although the R180 flange end may fit into the spline cavity, there is no way of securing it in place.
The replacement flange and halfshaft were sourced from a 260Z R200 diff.
All that is required now is some changes to the moustache bar.
https://www.sau.com.au/forums/topic/278979-diff-conversion/
  • Replies 55
Sorry! But no is the simple answer. The R200 is larger in diameter by about 20mm and therefore the moustache bar across the flats is about 10mm further back to accomodate this. Stewart Wilkins will make you one for about $100.00
Cheers, D
https://www.sau.com.au/forums/topic/278979-diff-conversion/#findComment-4713651
D, I just spoke to SWM and they'll charge me $250 for a new moustache bar.
So let's see now $1200 for the diff
$ 90 for freight
$ 360 for 260Z halfshafts( and that was mates rates) SWM would have been $470
$ 250 for moustache bar ( if SWM) fabricated it for me
$ 50 for posting the M-Bar
So this could all add up to about 2 G, not really that cheap. Thankfully I should be able to get a M-Bar made at work for about a 5th of that.
https://www.sau.com.au/forums/topic/278979-diff-conversion/#findComment-4714042
i dont want to seem like im advertising but if you are not in a rush i suggest you check out importmonster.
i got a moustache bar for like 10 bucks and new shafts for around 200. i bought a nismo 2.0way lsd for another 200.
i managed to find a r200 vlsd for 290 from a wrecker in ringwood. diff guy charged me $100 to fit the center to the
diff housing.
so if you shop around you can build it for way under 1k.
https://www.sau.com.au/forums/topic/278979-diff-conversion/#findComment-4714475
[Thanks for making me feel better Nick, LOL. Don't Import Monster charge heaps for getting it to ya?
I've used their calculation thingy and it just seems way too much sometimes. What price have you been charged and for what item bought to your door?
https://www.sau.com.au/forums/topic/278979-diff-conversion/#findComment-4714677
my stovetops invoice:
Item Cost: 18,000¥
Japanese Domestic Freight: 4,000¥
Import Monster Commission: 3,600¥
EMS Freight: 14,000¥
Total Japan Costs: 39,600¥
Exchange Rate: $1AUD buys: 69¥
Australian Domestic Freight: N/A
Sub Total: $573.91
GST: $57.39
Total: $631.30
i used the estimator but i actually over estimated the weight so the adjusted it for me and refunded the difference to my account.
i thought it was reasonable. considering they go into the effort of arranging pick-up/sending to their warehouse. then packing it and sending it to your door. and the convenience of having an aussie bunch of lads in the thick of Japanese parts. and there's so many part available for our cars!!
https://www.sau.com.au/forums/topic/278979-diff-conversion/#findComment-4714744
$ 90 for freight
I have some drawings or specs of the R200 Moustache Bar if you need them, but I warn you, they are for an R30. Does the C210 have the same, or offset like the Zed cars do?
$250.00 is a bit steep I think, particularly when it's mild steel, not spring steel (like leaf springs) as I would prefer.
Cheers, D
https://www.sau.com.au/forums/topic/278979-diff-conversion/#findComment-4714822
i just noticed that you are from wa. i had the luxury of being able to use the container for freight and picking up the items myself. heavy items like cv's and diff centres wouldnt be cheap to send to perth. i cant remember %100 how much i was charged for shipping as it was a while ago now..
https://www.sau.com.au/forums/topic/278979-diff-conversion/#findComment-4715149
Yeah, it has it's setbacks living here in the West. Import monster send their stuff to the east, and would'nt send directly to me. I've seen many parts I'd like to have snavelled, but the freight put me right off.
I'm getting the moustache bar done for free by the fitters at work. A
mate who works alongside them is picking it up this avo and taking it in for adjustments.
https://www.sau.com.au/forums/topic/278979-diff-conversion/#findComment-4716174
I climbed under my car yesterday to have a look and noticed something odd. I purchased a a late model r180 Subaru LSD centre, which is a flange and circlip type, and yet I am still using my original Datsun halfshafts, which are not the circlip type. The original Datsun bolt is holding the halfshafts in place.
There are two things I can think of:
1. The fellas at Jack MacNamurra diffs have a clever way of adapting Datsun halfshafts to a Subaru diff centre without the use of Subi flanges or making hybrid half shafts etc.
2. They kept the Subaru limited diff centre for themselves and gave me back a the original Datsun open-wheel diff!
Hopefully its the former.
https://www.sau.com.au/forums/topic/278979-diff-conversion/#findComment-4717280
Drew, you should take a couple of pics and post'em. I'm sure it would be of interest to many.
I'm left with 2 maybe 3 options with my moustache bar, so if you can help it would be appreciated.
Have a new one made.
Change mounts( bolted to the car) the moustache bar attaches too. Shift the bolts back 20mm buy making new plates.
Or if the R30 or Dr30 bar is close to my needs, I'll use one of these.( Really need a pic or 2 of these bars).
https://www.sau.com.au/forums/topic/278979-diff-conversion/#findComment-4717422
Easy way to find out?
Jack up the rear end and turn the wheels. If only one turns you have a single spinner.
Cheers, D
https://www.sau.com.au/forums/topic/278979-diff-conversion/#findComment-4718454
Hi D, Originally I was wanting to get it in quickly, now I'd be happy to have it in within a month. You got somethin on your mind, know where one happens to be lying idle by chance or you've got 2 jacks, a balaclava and a dark night lined up?
https://www.sau.com.au/forums/topic/278979-diff-conversion/#findComment-4718515
Hi D, You got somethin on your mind, know where one happens to be lying idle by chance
Funny you mention this!
I just happen to have one I can put my hands on as I type this message.
It's called Ghostrider Spares lol
But seriously, I need to use it as a template for the late model R230 style finned diff rear covers. As you're in need of something fairly quickly, I'll try to get mine made or at least ordered next week, Tuesday or Wednesday when I'm off next. I want mine made from leaf spring type material, as opposed to SWR's mild steel.
If you can wait a couple of weeks it will probably be for sale?
Cheers, D
https://www.sau.com.au/forums/topic/278979-diff-conversion/#findComment-4719008
Is this going to be a "straight bolt in" job, gee I hate using that term. So does this prized piece of steel fit my requirements, ie the 2 main bolt holes are the same as mine, but the bar is 20mm shorter as such, the R200 being that much longer. Yes I'll wait if this eets my need without further alteration. Cheers Ricky
https://www.sau.com.au/forums/topic/278979-diff-conversion/#findComment-4719065
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
