"Why are you checking the cam timing? Are you looking for a problem or just trying to create one?"
Yes i actually do have a problem!
This is an engine i got from an importer and installed in a C35 laurel chassis.
The engine at idle is a little lumpy even though i cleaned aac / throttle bodies etc, plus when given a quick rev it gives a "noisy tappets kinda sound as it falls back to idle and then is normal again at idle.
The other noise that had me concerned and made me start investigating is an "over tightened timing belt" kinda groan coming from the exhaust rocker cover in line with the no. 2 piston.
This noise is very audible and can be pinpointed to this one spot using the ole screw driver method, and only happens when the car is up to temp.
So i guess this may be the reason my idle is lumpy?!?
And can some one pls tell me what this groaning noise might be ???? it really has me bummy!
Cam bearings?
Cheers
Gary
  • Replies 44
Hmmm overtightened cam caps??? Check and also make sure that the CAS is not overtightened as well. Remove the balancer and line up the gears and the crank properly replace and tighten the tensioner to factory specs. I think SK has a detailed sticky on how to set the timing for the RB25DET, the FSM as well. Use a long screwdriver as well when getting TDC on number one and at the same time ensure that all others are in sync as well.
I know these have specific markings on the to tell their location, but can i swap it with another one to hear if the noise "moves" to the one that i swap it with?
Or maybe use one from a 25det as i have a spare head? Not sure if they are the same tho.
Just trying to figure out how to diagnose the problem.
Thanks.
Cam caps are specific and need to be line bored to work, using from a next head can cause the cam to snap upon torqueing. Slacken them per FSM order and retorque if you think it may be a problem. I suggest try getting the timing fixed before looking at a next problem.
Cas is not overtightened, even changed it to make sure that wasnt the problem.
Going by wall on Saturday to get the timing sorted out
update
Well i took out the balancer today to check the timing, and what do ya know, it was spot on, all three marks lined up.
The good part is now i know the "overtightened timing belt" sound i was distinctly hearing from the ex cover around piston 2 was actually because the timing belt was overtightened!!
What can i say....It's funny how sound travels in engines i guess :bunny: . I have slackened the belt which has eased it up some, but there is still a faint sound, but i guess i'll have to live with that till i go back in there to put on my adj. gears.
So now a new question!
Like i said before, when the cams line up the balancer reads about 5*. So when i set my timing (20*) using a light ,does it mean i now have to set it to the 6th mark oh the balancer which originally would have been 25* but in my case would be 20* ?!?
I have it set to the 5th mark right now, which in my case should be 15* and the car gives me a slight ign rattle when pulling off with the ac on.
Should i advance it to the next mark to get the 20* or leave it as is? Our best fuel here is 95. I run stock ecu, 12psi when the weather is 'hot' and 14 psi when 'cool'
Thanks again
Thanks again
It's not physicaly possible for the crank sprocket to line up with the TDC mark while the damper lines up with the 5 degrees BTC mark, unless the outer damper ring has rotated on the inner hub and/or the keyway is worn and/or in the wrong place. Either way you need to find out why the timing marks don't align before you go any further. A detached damper or bad keyway are small problems that will get quite huge if not fixed.
Cheers
Gary
Correct me if I'm wrong, and it has been a while since I actually took notice of this, but the R32's run the orange mark at -5deg.
I know you have a 33 but is it possible you have a 32 balancer or something silly like that?
Therefore the second mark from the left is actually 0.
Like I said, it's been a while but I'm fairly sure this is the case and from memory I read it in the 32 manual also.
Well i dug up the R32 GTR manual and the first mark on the balancer is 0* also, so no luck there either!
As i said the keyway is normal, but i noticed in the manual it states "Crankshaft key must be facing up"
Does this mean directly up as in 12 o'clock?
Cause mine faces probably about 11 o'clock with everything lined up.
Anyway, i am baffled as to why it is not lining up to the 0* mark, but not too concerned as i know the crank and cams are lined up to spec.
So what do i do, take the second mark (5*) as 0* and adjust my timing from there???
If your keyway isnt dead at 12 o'clock, chances are no1 piston is NOT at TDC. Check it with a dial indicator to make sure it is, otherwise your timing will be off.
Also as I stated on the other page and as Daniel stated, im pretty sure on r33's the second dash is 0, first line is -5. Im pretty sure that explains why the second line on my balancer is orange and the others are white.
Just checked, the first line on my balancer is orange.
And both the R32 & R33 GTR manual has the first mark as 0*
That must be the difference between a gtr and gtst then.
Eitherway I would check that the piston is at TDC when the cams are aligned with the markings on the back camshaft timing cover. Even if you just do it the old fashion way with a screw driver down the sparkplug hole...
I had this issue on my car. after alot of f**king around I worked out that my marks on the harmonic balancer is...
-5 0 5 10 15 20
It is a RB25 balancer. from which RB25 i am not sure because i got it from wrecker. Maybe the RB25 balancers are different to the R33 R34's in the markings.
As long as the thing is timed correctly on the pulleys then you will be fine, just set the timing with the balancer on 0 in your case.
    • I'm so far behind in the jobs I have to do at both work and home (including car) that I have become immortal. There's simply no way that I can die now.
    • Each to their own I guess  Me, I put just as much time into cleaning inside of the cars as I do on the outside As for getting wet, it is really no different than steam cleaning the carpets at home, apart from the cars carpet dries alot faster than the house, again, I only do it in the hotter months and leave the car opened up for a few hours As I only do it yearly, it is just before I do the diff and gearbox service, so I clean the carpets, then it's up on stands, wheels off, service, clean the undercarriage,  grease the bushings and do a nut and bolt check on everything  Disclaimer: I typically had all the time in the world to kill when I was working 馃ぃ, so spending a full day or 2 cleaning, serving and "looking at stuff" was,  easily achievable, and a fun mental therapy day As for time to kill, I retired last Wednesday, so apart from my physical training, my days are filled with lots of random jobs around the house and garden...."Idle hands are the Devils something something" I am also buying a new house sooner rather than later, I'm actually looking at a potential property tomorrow, I'm looking forward to getting a car hoist as I'm starting to get to old to crawl around under a car, I can only imagine all the undercarriage cleaning and looking at stuff when that gets set up
    • Yeah, I'm not interested in wetting the carpets, and I don't care about brown dirt/dust that lives deep in the pile or underneath. It's not like I crawl around on them in my birthday suit or eat dropped food off them (because there is never any open food in my car). The seats are alcantara (cheap Chinese imitation alcantara, to be sure!) with barely 1" of foam pad behind the surface. That's not getting wet either. Any car that I would be happy to get the interior wet, I would not care to put the effort into.
    • We have one that holds 2.8L of water. On floor carpet that hasn't been touched in 2 or 3 years, will take a minimum of 2 fills of the tank to do a bedroom, and that's going AROUND the bed.   In the cruiser, I used an ENTIRE 2.8L tank, just on the front passenger footwell. But it had some fungus growing, and had been full of mud from being used as a 4WD for many years. I can do that floor again, and it will still pull mud out. However, the water now only looks dirty, not pitch black and leaving full sludge in the bottom of the tank it sucks back into. Oh, and, this is about a $1500 unit.
    • This is mine, works a treat for the cars, suction is good, I use the Bissell clean and protect stuff I have found giving it a good spray and light scrub with the soft brush on the head of the nossle for carpet, and a rub with a microfibre for cloth seats and cloth door trims, prior to another quick spray before vacuuming it up works the best @GTSBoy You would surprised on what it gets out of carpet and seats that actually "look" clean, I recommend that you test drive yours when you have a little time to kill, then post pics of the muddy looking water that I believe you will find
