Hey guys..
Wondering if anyone can help me out i own an R33 Skyline GTS25T, and recently when i have been starting to first roll in first gear, or in reverse or when im stoping. There has been a clunky sort of noise coming from the rear. It sounds similar to if you let your toolbox sit loosely in the boot and when you stop and move it slides around hitting things.
After some advice or help if possible
Cheers
https://www.sau.com.au/forums/topic/279067-clunking-noise/
Obviously you've checked the boot for anything loose? Could have to do with your suspension system, not necessarily the suspension itself but a broken swaybar mount, etc. Got anywhere you can take it to for a look?
https://www.sau.com.au/forums/topic/279067-clunking-noise/#findComment-4714998
I have the same issue and I do hear the sound when I'm slowing down and also sometimes when I stop at lights, kinda sounds like a little 'donk' (it will do this once each time). It can also hear it when I take off sometimes too, it's very noticable when the car is cold and I roll out of the garage.
https://www.sau.com.au/forums/topic/279067-clunking-noise/#findComment-4715385
Differential gear oil should be inspected every 10,000Km
LSD gear oil (according to the manual) has a higher viscosity & temp. threshhold and should be changed every 40,000Km
If LSD Gear oil gets too thin, gets too low or breaks down, you'll hear clicking between acceleration & deceleration & back again whilst travelling at low speed.
https://www.sau.com.au/forums/topic/279067-clunking-noise/#findComment-4715710
This also started to happen to me after I changed my subframe bushings and diff bushings to aluminum.
Maybe one of your bushings is completely finished.
https://www.sau.com.au/forums/topic/279067-clunking-noise/#findComment-4715826
I don't' want to hijack this thread but just to add to my previous post. Ever since I bought the car (December 2007) I have regular services done on my car and I know the last service all fluids were changed, it's nearly time for another one so I'll mention it to the mechanic and see what they think.
I can't be 100% to say that this was happening from the day of purchase, I'm also guessing if it is that the oil has gotten too thin this won't be resolved simply by changing it now would it.
Does it mean it's time for a new diff?
https://www.sau.com.au/forums/topic/279067-clunking-noise/#findComment-4717335
nope not at all... your old diff is still quite good, from the sounds of it, people might disagree with me but if ur low on oil and its clicking you know its engaging... prob not the best thing to have but wont hurt it too much,.check your oill and dont be a cheap ass... buy the good stuff,... its a lot cheaper than a new diff.
if the clicking keeps going . look at shimming it up .
but in my case there were jsut some loose subframe bolts...
when you put rose jointed camber arms and such items there will always be a little clunk.... when you roll back and break or forward and break...
good luck
ps if ur diff starts wineing then youve got problems....
https://www.sau.com.au/forums/topic/279067-clunking-noise/#findComment-4721558
Thanks for the help..
Terry GTR-34: i tried what you said, with the 20km accelerate and decelerate. It does it occasionaly, but more so when i first take off and under braking.
Any suggestions or help.
Thanks for the assistance guys. Ive only just got my car and i'm not very mechanical, and want to lear more, so any help is appreciated.
Cheers
https://www.sau.com.au/forums/topic/279067-clunking-noise/#findComment-4737925
sounds like the same issue with mine, but mine is much worse.
Besides the diff being stuffed, I have WAY to much backlash in the diff, but a 2nd hand one, preshimmed ready to put in when i get a chance
https://www.sau.com.au/forums/topic/279067-clunking-noise/#findComment-4738092
^^^The centre universal joint on the tailshaft has been known to go weak on the R33 with rapid acceleration.
On a hoist, your mechanic can push up on it from underneath to 'feel' if it's soft or...
you yourself can drive the car along a freeway and say...
a) drive for 10-20sec at constant 100 Km/Hr
b) do the same at 110 Km/Hr
c) do the same at 120 Km/Hr
d) do the same at 90 Km/Hr
...and if you feel vibration through the car, you may require a replacement tailshaft.
If so, it shouldn't cost much or require much time to replace it.
Make sure it's the same part that corresponds with the same model of your car. For instance, the tailshaft on a R33 GT-R V-Spec is different from that on a non-V-Spec.
Position of cup & axis is important too. Better still, let your mechanic do it if it's a tailshaft. Labour time is quick.
Get the mechanic to replace your diff oil whilst you're at it. It might only be this after all.
https://www.sau.com.au/forums/topic/279067-clunking-noise/#findComment-4738421
I tried that and there was no vibration through any of those speeds. Does that mean its just diff related.
Does anyone know any good mechanics i can take it to.. One that wont take advantage of my lack of knowledge anyway.
Im in the wollongong are but i dont mind driving to sydney..
https://www.sau.com.au/forums/topic/279067-clunking-noise/#findComment-4742802
Wollongong to Kirrawee ain't far!
Garry is the technician at Just Jap 02-95450532
Call Darron, Steve, Tim or Daniel to make a booking. They won't charge you any steep hourly rate either. Very fair and...
Most of all, good diagnostician.
If you have a real low lip on the front, just take the entry gutter at an angle.
101 Bath Rd Kirrawee
Make sure you tell us the results!!!
https://www.sau.com.au/forums/topic/279067-clunking-noise/#findComment-4743556
I had the same problem so I got the car checked out, and we diagnosed a centre bearing in the tailshaft had completely shat istelf, as well as the uni joints on either side of the shaft.
So I got that replaced with a custom 1 piece shaft, very happy and there wasn't any vibrations when taking off etc, but the clunk is still there.
I think I can safely say my LSD needs some new oil? It's had a hell of a workout this year as I have started drifting...
https://www.sau.com.au/forums/topic/279067-clunking-noise/#findComment-4769335
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
