The rev debate...... (apart from racing regs duncan)
Who needs more than 9000rpm anyway, apart from RIPS who pulls 10,000 from his drag car (still stock block and crank) I fail to see the problem.
As the 26's also require. A good set of rods, pistons, aftermarket balancer and the ol' rb30's in their thongs and black skin tight jeans hang in there for 9000rpm no issues.
9000rpm+ for an RB30 is well in to GT45 hp territory lol.
The old RB30ET's with a little headwork + cams push 8000rpm on stock rods lol (with a balancer) and RB30ET pump. Not the DOHC crapo style pumps.
  • Replies 83
Posted Images
unless you happen to get some miracle price in the first place (or buy something thats going up in value aka not a skyline) you never get your money back on a car modified or kept bog stock.
yes thats true. you will never get the true value of the car back.
but ill rather spend more cash on a Virgin skyline than somones else whore of a skyline what's been around the block. :down:
so having a stroker kit makes it look like a virgin but having more power with aftermarket blot-ons :P
who trent? I need to fit a 30 crank in a 26 block
did you ever speak to crank shaft rebuilders? if not i will ask when i go down next. I have a few GTR cranks to get straightened that i acquired from here and there.
I know this is a little off topic and a little Tabooo. BUT does any 1 know of any attempts to mate a ford 4L Barra 6 to a GTR front diff/transfer case?.
aside from the fact that trying to fit a Ford engine to a Nissan is probably classed as a crime against nature under international law, the front diff and steering components would cause one helluva headache with regards to exhaust routing
  • 5 weeks later...
I saw it this way back in 1999 with first RB30 in R32 I did and I still see it the same way now. What am I missing?
Cheers
Gary
your missing the fact that if ur car is registered (at least in qld anyway), it is completely illegal to put an rb30 in any car built after 1989. before u start saying "grind the numbers off" thats even more illegal. some of us want to keep our cars on the road rather than defected every time u drive it. the cheapest option is not always street legal.
it is entirely possible to have a street legal 30. they have been done before and will be done again if the car came standard with a 2.5L or 2.6L engine the 3L falls within the 20% capacity increase. combined with emissions testing and an engineers certificate for the modifications you have it is a legal mod. (though this is affected by which state you live in vic and SA seem to be the hardest to get it done in)
uve got it all wrong. swapping an RB25 or RB26 over to an RB30 is not a capacity increase like using a stroker crank. changing engine blocks is an engine swap. in QLD (dunno how other states view it) u cannot put any engine into a car that is newer than the engine. so if the engine was not oem equipment for the car it must be the same age or newer. EG: if ur car is made in 1994 ur engine must be 1994 or newer.
i dont remember exactly but something about emissions and safety standards. so if u do happen to get pulled up by qld transport (which i have been many times) and they discover uve broken this rule, be prepared to walk home!!
i'll call the modifications office again and get a clear and definitive answer on the reason.
the age rule does not apply to a change of the bottom end as all the emissions stuff is in the head (or connected to it) and the tune which remain the same age or newer than the engine that was in there
it is in essence the same as using an OS Giken RB30 kit except the block already has the spacer plate integrated from factory.
You need to re-read your rules and regs...
You CAN put an old engine in a new car, BUT you have to get said old engine up to new car emmision laws...
That is the rule, emmisions must meet what ever is newest.
not yet, no rush atm....but its good to know options when we're ready to go :P
I'd copy the OS Giken process, RB30 crank, RB26 rod length, 2 head gaskets, 12.3mm (1/2" milled) spacer plate and tall liners. With an 87 mm bore that will give you 3,069 cc's. That's 600 cc's (~20%) more than you have with a standard RB26.
Not an ideal rod stroke ratio, but OS Giken weren't totally wrong, it's about the best you can get from an RB26 block. You can't use RB30 length rods as the spacer plate would be too thick (30mm) and the cylinder liners would poke out of the block too far.
All you have to do is give a headgasket to a machinist and say copy that in 1/2 steel plate. Mill the spacer plate flat, bolt it on an RB26 block and then have the liners installed, shrink to fit, then bore to 87 mm and deck. Not a big deal really.
Cheers
Gary
If you're going to go the spacer plate route you're better off using an SR20 rod seeing you're already making a spacer plate you might as well get the rod ratio better. You also get 22mm pins as a bonus. You need to reduce the stroke slightly to get everything to turn inside the cradle without a lot of modifying and it's not a big hassle given you need to machine the big end journals down anyway to fit the RB26/SR20 rods.
I had one dummied up ages ago and it's a lot of work to do, crank work, flanged sleeves, spacer plate, custom studs, sealing the spacer plate etc etc.. using an RB30 block is a lot cheaper. Not necessarily better but definitely cheaper.
Interesting discussion on rod / stroke ratios.
the current gen MOPAR R5 nascar engines run a 3.25" stroke with a 6.25" rod at 358cubes so the ratio is 1.923:1 and make 800+hp aspirated through a single 4 barrel :down:
They do however have the advantage of a big bore V config block to get a short stroke long rod combo that we unfortunatley arnt blessed with in a skyline unless we want 1.6L RB26s that rev to 14k lol
Im actually suprised the likes of Harrop / C.O.M.E racing havent produced a cast stroker crank for the RB's...no real need for billet unless you want 10000rpm imo
Market is way to small.
so after 2 hours on hold i finally got through to someone in the modifications department. i explained the idea of an rb30 into a skyline and straight away was told it could not be blue plated because of the engines age. but after explaining the idea of using the skylines oem head and pollution control all i could get was a maybe. the fellow was unsure as this is a grey area in thier rules.
he said to talk to an engineer that can blue plate engine swaps and see what they say. so far ive spoken to 5 and they all said they wouldnt do it. so there u go, if u can find an engineer to pass it, ur in the clear i guess.
Just had an rb30 r33 passed roadworthy (blue slip) in qld
let us all know who approved it for u so we can get it done.
The RB30 was available in the GQ patrol upto 1997 anyway, so moot point.
even though its kind of irrelevant now, how is it a moot point if u have a 98-99 model??
    • A lot of the trim pieces on the E39 are super brittle and just dissolve when you try to get them off. It looks like a previous owner has used what can only be described as an industrial construction foam adhesive to glue down a tiny piece of trim.  Unfortunately this part of the tailgate is starting to rust because of how much shit is in here. This is stopping the water draining and there's a big build-up of dirt that is just staying wet. How can I remove this? Would a flap disc get rid of this?  I think this car spent a lot of time inland. There's so much light coloured, fine dirt and dust everywhere.  Sorry for the pic. I've cleaned this all up now so I'll get another pic of it clean today.
    • Surely, just about any shop that has done a Skyline (or Supra, or RX-7, or EVO, or WRX) will have done E85. But perhaps you need to specify what type of car, what type of engine, what ECU, you propose to be using.
    • Try an oil additive. There's a couple of options for "easier shifting". These are essentially a similar idea to what Redline put into their Shockproof gear oils. I had a 2nd hand R33 (in fact, as of right now, it is still in the car) that simply would not engage any gear with the engine running, with normal gear oil in it. We dropped that and replaced it with Shockproof lightweight, and suddenly the gear lever did what it was supposed to. At a cost, of course, of the then ongoing damage to internals done by running Shockproof. But the synchros were already totally uninterested in life, so there was no loss.
    • It always ends with the car burning down.
    • I see what you posted, but how could a warning light be going on and off if there is no sender for it?  The only other explanation is that the wire that used to go to the sender from the warning light is earthing somehow in the loom or at the connector, or that you have connected the warning light wire to something (maybe the temp sender?).
