Sau Gaming Nights Are Here---!***
R31Nismoid
 Share
  • Replies 73
You can actually play on deathmatch servers where it's just like normal CS but instead of buying guns you just choose which ones you want. And instead of waiting for the round to finish you respawn 2 seconds after you die, just like in a Quake game. Gets very addictive and is very straining on the senses lol.
I'm just pissed off that I couldn't join you guys last night...Installing Orange Box (and CS:S) took longer than I expected...I forgot I needed to upadte all and it still forever to complete. I'll be ready for next week...
Now just need to some minor tweaking of my PC (silly IDE HDD playing up with my system - going to move that to my old PC and make that my downloading machine and get another SATA HDD for my PC)
^+1, its only $20 or so anyway.
You guys need to play CSS RPG :/ I'm mainly on internode. Its heaps better, stealth, 500hp, frost pistol.. etc
Haha, I used to play that... the frost pistol so ruined that game :domokun:
anyone find me a good reliable torrent for cs:s...might play for hour or 2 every thursday b4 hit up loulous or something lol
LouLous :/
Better off stayin at home and continuing to play CSS lol.
Just buy it off Steam, it's dirt cheap these days.
ill make it to the next thursday one, if only for an hour or so but still... just need to know if it's css or not :down: haha
used to pro cs up back in the day.. meh to it all now...
anyway see ya next thurs :)
 Share
    • there are probably many ways to do it for my bosch motorsport abs we used a r33 gtst abs front knuckle and modified the rear knuckle to allow sensor to sit and read understand time, effort and $$ but reading from anywhere else  you get diff chatter etc where you lose 30% ish in signal clarity compared to the above
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
