hey, pretty new here and n/a 33 owner just a couple of quick questions
i no there is all this exhaust extractors etc stuff but in a couple of topics ive seen things like camshafts and ecu's
but ive curious as to where to buy bigger cam or something and a blitz ecu????
im all about modding my 33 as its stock except for exhaust and extractors.
ive come up with a couple of things i wanna do to it but not sure if there worth the power gain for the money (btw im on my p's)
*bigger throttle body
*bigger camshafts/valves/springs etc (heard that u can use rb20 gtst cams but not sure)
*some sort of intake upgrade
if you could even fill me in on what some prices could be would help cheers
Edited by n/a_r34GT
in the bit that has your user name and amount of posts etc it says that you have a R34 N/A but you are saying you have a R33 N/A.....which one is it????
My first (well second really) question to you is : what are you wanting to achieve with your car?
Why do you want a Blitz ECU? Why not go with a GReddy Emanage, or even a Apexi Power FC???
Generally speaking, if you want bigger cams, its always a good idea to get head work done aswell so you get the most out of having the bigger cams, then you may have to consider about upgrading your fuel injectors too.
You shouldnt have to worry too much about getting an overly stupid sized bigger throttle body, i would recommend talking to your tuner and seeing what they recommend.
In regards with the intake setup, generally you can just get a pod filter, and have a cold air intake set up to go to the pod.
Also you will find that you will not be able to use RB20 cams in a RB25 engine.
oh ok true...about the r34 thingo is cause my mate wanted to and end up importing a r34 gt and i was just using the account to answer this and that other question but i actually do have a 33
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
