n/a_r34GT Posted July 14, 2009 Share Posted July 14, 2009 (edited) hey, pretty new here and n/a 33 owner just a couple of quick questions i no there is all this exhaust extractors etc stuff but in a couple of topics ive seen things like camshafts and ecu's but ive curious as to where to buy bigger cam or something and a blitz ecu???? im all about modding my 33 as its stock except for exhaust and extractors. ive come up with a couple of things i wanna do to it but not sure if there worth the power gain for the money (btw im on my p's) *bigger throttle body *bigger camshafts/valves/springs etc (heard that u can use rb20 gtst cams but not sure) *some sort of intake upgrade if you could even fill me in on what some prices could be would help cheers Edited July 14, 2009 by n/a_r34GT Link to comment https://www.sau.com.au/forums/topic/279147-camshafts-etc-for-a-na-skyline-plz-look/ Share on other sites More sharing options...
MissR34 Posted July 14, 2009 Share Posted July 14, 2009 in the bit that has your user name and amount of posts etc it says that you have a R34 N/A but you are saying you have a R33 N/A.....which one is it???? My first (well second really) question to you is : what are you wanting to achieve with your car? Why do you want a Blitz ECU? Why not go with a GReddy Emanage, or even a Apexi Power FC??? Generally speaking, if you want bigger cams, its always a good idea to get head work done aswell so you get the most out of having the bigger cams, then you may have to consider about upgrading your fuel injectors too. You shouldnt have to worry too much about getting an overly stupid sized bigger throttle body, i would recommend talking to your tuner and seeing what they recommend. In regards with the intake setup, generally you can just get a pod filter, and have a cold air intake set up to go to the pod. Also you will find that you will not be able to use RB20 cams in a RB25 engine. Link to comment https://www.sau.com.au/forums/topic/279147-camshafts-etc-for-a-na-skyline-plz-look/#findComment-4714918 Share on other sites More sharing options...
n/a_r34GT Posted July 15, 2009 Author Share Posted July 15, 2009 in the bit that has your user name and amount of posts etc it says that you have a R34 N/A but you are saying you have a R33 N/A.....which one is it????My first (well second really) question to you is : what are you wanting to achieve with your car? Why do you want a Blitz ECU? Why not go with a GReddy Emanage, or even a Apexi Power FC??? Generally speaking, if you want bigger cams, its always a good idea to get head work done aswell so you get the most out of having the bigger cams, then you may have to consider about upgrading your fuel injectors too. You shouldnt have to worry too much about getting an overly stupid sized bigger throttle body, i would recommend talking to your tuner and seeing what they recommend. In regards with the intake setup, generally you can just get a pod filter, and have a cold air intake set up to go to the pod. Also you will find that you will not be able to use RB20 cams in a RB25 engine. oh ok true...about the r34 thingo is cause my mate wanted to and end up importing a r34 gt and i was just using the account to answer this and that other question but i actually do have a 33 Link to comment https://www.sau.com.au/forums/topic/279147-camshafts-etc-for-a-na-skyline-plz-look/#findComment-4716902 Share on other sites More sharing options...
MissR34 Posted July 15, 2009 Share Posted July 15, 2009 yeah thats cool dude, just wasnt too sure what was going on lol Link to comment https://www.sau.com.au/forums/topic/279147-camshafts-etc-for-a-na-skyline-plz-look/#findComment-4716936 Share on other sites More sharing options...
