Hi All,
Advertising this for my little brother.
HPI SAVAGE X 4.1
Up for sale is my hpi savage x 4.1, I bought it for $900(plus $450+ in options) on it 2 years ago and have not since used it for at least 1 1/2 years ago.
Truck has only had about 5-6 tanks of fuel in and I had not even fully broken in the engine yet.
Last time I drove the truck I broke the rear diff (crown gear I believe) but it’s only about $15-20 and 5 minutes to change. Apart from that the truck has usual scratches but over all it is in very good condition (a clean wouldn’t hurt).
Features the usual such as- alloy diffs, 2 speed transmission, 8 oil filled coil over shocks, TVP (twin vertical plate) chassis, full time shaft driven 4wd, 4.1cc big block engine, 160cc fuel tank for long run time, tuned pipe, 17mm alloy hex drives, roll cage, 2 stage air filter, roto starter with charger for easy convenience, etc.
Additions over the standard savage x 4.1 are:
• wheelie bar
• muffler silencer
• twin stainless steel disc brakes
• Mounted nubz tires s compound on a black dish wheel (was about $200 dollars with the correct hexes as well).
Also glow plug igniter and charger will come with truck amongst other spares ie: glow plugs, filter`s, rotor starter and charger and other miscellaneous items(no AA batteries come with it).
All that is needed to get this truck going once again is a crown gear for the diff($15-20) and some fuel.
After $400 for the lot!
I would prefer a local pick up but I will post at the buyers expense. Pick up can arranged for either Clifton Hill or Reservoir.
Thanks,
Justin.
https://www.sau.com.au/forums/topic/279151-fs-vic-hpi-savage-monster-truck/
PARTS SUPPLIED ARE:
truck
body(beaten up)
full radio gear(includes servo`s etc)- the antenna at the top is broken but it still extends to about 50 cm(new one is $19.95)
6 AA 2500mah rechargeable batteries(need another six, which from memory is $40) and a 1hr quick charger
roto starter with a 2000mah rechargeable battery and charger
a tack box filled with dual stage filters, filter cleaner, thread lock, diff gears, slipper clutch and other miscellaneous parts.
all that is needed to get the truck running is 6AA batteries,fuel and a crown gear($15-20).
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
    • The downside to that is that the cost of everything, particularly labour, is significantly higher here than it is over there in the Disunited States of Slavery. You can hire 3 tradesmen over there for just the Ranger Raptor allowance of a single 3rd year apprentice over here.
    • Shit. Starting to look like a car again.
