Fs Vic - Hpi Savage Monster Truck
private9
 Share
Hi All,
Advertising this for my little brother.
HPI SAVAGE X 4.1
Up for sale is my hpi savage x 4.1, I bought it for $900(plus $450+ in options) on it 2 years ago and have not since used it for at least 1 1/2 years ago.
Truck has only had about 5-6 tanks of fuel in and I had not even fully broken in the engine yet.
Last time I drove the truck I broke the rear diff (crown gear I believe) but it’s only about $15-20 and 5 minutes to change. Apart from that the truck has usual scratches but over all it is in very good condition (a clean wouldn’t hurt).
Features the usual such as- alloy diffs, 2 speed transmission, 8 oil filled coil over shocks, TVP (twin vertical plate) chassis, full time shaft driven 4wd, 4.1cc big block engine, 160cc fuel tank for long run time, tuned pipe, 17mm alloy hex drives, roll cage, 2 stage air filter, roto starter with charger for easy convenience, etc.
Additions over the standard savage x 4.1 are:
• wheelie bar
• muffler silencer
• twin stainless steel disc brakes
• Mounted nubz tires s compound on a black dish wheel (was about $200 dollars with the correct hexes as well).
Also glow plug igniter and charger will come with truck amongst other spares ie: glow plugs, filter`s, rotor starter and charger and other miscellaneous items(no AA batteries come with it).
All that is needed to get this truck going once again is a crown gear for the diff($15-20) and some fuel.
After $400 for the lot!
I would prefer a local pick up but I will post at the buyers expense. Pick up can arranged for either Clifton Hill or Reservoir.
Thanks,
Justin.
PARTS SUPPLIED ARE:
truck
body(beaten up)
full radio gear(includes servo`s etc)- the antenna at the top is broken but it still extends to about 50 cm(new one is $19.95)
6 AA 2500mah rechargeable batteries(need another six, which from memory is $40) and a 1hr quick charger
roto starter with a 2000mah rechargeable battery and charger
a tack box filled with dual stage filters, filter cleaner, thread lock, diff gears, slipper clutch and other miscellaneous parts.
all that is needed to get the truck running is 6AA batteries,fuel and a crown gear($15-20).
 Share
    • Yeah I noticed this just now. No doubt she will be running smoother next start😂🤣😂
    • ENR34 manual transmission transfer cases are 33100-23U00 which is shared with all of the R32/R33 GT-Rs and GTS-4s. And the C34 Stagea. Do not bother with automatics, that is a huge effort to swap and the car will be worse for it. And an automatic transfer case does not have the right housing for the shifter which comes out the back of the transmission and goes through the transfer case. I already posted my response on reddit but if you didn't see it there here it is: You have almost certainly damaged the transfer case, the only question is how badly. Nobody can tell you how bad without more information. If you have a giant hole in the transfer case pissing out all the transfer case fluid then you need a new one. If it's not that bad then the only question is whether you burned up the clutches. Drain the transfer case oil and inspect for metal on the drain plug magnet. Small black filings are normal. Big chunks of metal or a ton of black fuzzies not so much. Fluid should be nice and red. Any other color isn't great. If the color is reasonably red and there's not a bunch of clutch material discoloring it or anything like that you probably got away with insubstantial excess wear not worth trying to fix. If you have to rebuild or replace the transfer case keep in mind you have to pull the transmission to get it off.
    • As promised………… the first start. Rough and a few bugs to work out. Still she lives att.1cnTUvrWxiOZUFbg0S43m1VFUdDhxGBq3UU53bvtkww.mp4
    • Can I suggest a 15W50 oil is too heavy. Its a brand new engine - you should be able to run something like a 10W30. Shove some steel wool into your catch can  - more technically "oil/air separator" - so that the oil vapour has something to condense on.
    • Nice write up solder thank you.  that problem had fallen into another days fun. I wanted to get this cold side in and turned over so it was wired up the same to get a start. no luck I got a couple of cough’s before the battery died unfortunately. we have some wether on the way and I’m back to work, I will order your plugs and re wire them in the near future. 🤙
