Was wondering if there were any options to upgrade the stock open diff that comes in the Auto V35?
I have found that on take off @ a busy intersection the back left wheel will break traction easialy and then traction controll will kick in and everythig slows down. Was thinking that a LSD would help since power would go evenaly to both rear wheels. Have also noticed this when turning right and giving it a bit of stick mid turn
  • Like 1
https://www.sau.com.au/forums/topic/279164-auto-diff/
Taken from this site
Z33 - MT - R200 - 3.538
Z33 - MT - R200V - 3.538
Z33 - AT - R200V - 3.357
Z32TT - R230V - 3.692
Z32 - R200V - 4.083
G35 - Sedan - AT - R200 - 3.357
G35 - Sedan - MT - R200V - 3.538
G35 - Sedan - AWD - AT - R200 - 3.357
G35 - Coupe - MT - R200V - 3.538
G35 - Coupe - AT - R200 - 3.357
G35 - Coupe - AT - R200V - 3.357
Q45 - G50 - R200V - 3.538
Q45 - FY33 - R200V - 3.692
R32 GTR - RB26DETT - MT - F160 - 4.111 - (Front Final Gear)
R32 GTR - RB26DETT - MT - R200 (Mechanical LSD) - 4.111
S15 - MT - R200H - 3.692
S15 - AT - R200V - 3.916
S14 - KA24DE - 4.083
S14 - SR20DET - MT - R200V - 3.692
S14 - SR20DET - AT - R200V - 3.915
S13 - KA24DE - 4.083 - (Both R200 and R200V
So im guessing that a R200V is the stock viscous "spelling" hence the V LSD
so if thats the case then if I can find someone with a S14 MT whos pulling out their diff centre to fit a 1.5 or a 2 way mech centre then I should be able to swap my diff centre with theirs and have a LSD with a similar ratio to what the stock open V35 LSD is? It also looks like the 350z Z33 autos came with a LSD well according to the site this info is from and it also has the same 3.357 ratio
OK now for the NOOB question will a higher ratio eg 4 give better acceleration and less top speed than a lower ratio eg 3? im thinking that the higher the ratio the less top speed but faster accel
Edited by 180 wanabe
  • Like 1
https://www.sau.com.au/forums/topic/279164-auto-diff/#findComment-4717018
well the ratio of the Z32 is 4.083 and id like to keep the rato as close to stock as possivle hence why the S14 MT ratio of 3.69 is closer to the stock ratio V35 auto ratio of 3.357. Also findind a S14 owner whos upgrading their diff centre will be a lot easier than a Z32 owner. After all when I had my S13 and I had a KAZZ 2 way put in my old diff centre went in the bin.... didnt think it was worth anything and im sure most S14 owners would think the same
  • Like 1
https://www.sau.com.au/forums/topic/279164-auto-diff/#findComment-4717179
Well im no mechanic... but would love it if someone who knew about these things could come post and enlighten us
but one would think that a R200 is a R200 just like a SR20 is basicaly the same SR20 weather it be a S13 14 or 15... I know that there are differences in the plenum cams and other stuff but just using that as an example
  • Like 1
https://www.sau.com.au/forums/topic/279164-auto-diff/#findComment-4718714
except that FWD SR20s are different engines to RWD SR20s :P
but afaik an R200 rear end contains all the same internals (except ratio and if its LSD equipped), i think only the rear casing is different as per the car that its installed into. i dont even think you need to get the ratio the same (assuming its an RWD V35) if you want longer gearing or shorter, the speed is taken from the ABS signal taken after the final drive....
  • Like 1
https://www.sau.com.au/forums/topic/279164-auto-diff/#findComment-4718808
Some comments
I put a new front coupling on my diff and the shaft is bigger than the R32/R33 ones, just makes me question compatability.
Z32 is an R230 so incompatable.
Would also be cautious with changing the ratio with the auto, need to check if this would impact anything with the auto output shaft comparison with ABS signal within the transmission computer.
Hope this is helpful.
  • Like 1
https://www.sau.com.au/forums/topic/279164-auto-diff/#findComment-4718894
actually id like to change wat i said, the entire casing may be different lol just change the internals :P
the ABS signal only sends back the speed of the wheel no matter what ratios are before it. ABS doesnt know what gear youre in or your final drive ratio.
  • Like 1
https://www.sau.com.au/forums/topic/279164-auto-diff/#findComment-4718965
Yeah i was thinking it would be easier to just change the internals like when I had a kazz centre put in my 180sx diff
I had a feeling that the speedo came off one of the wheels or something so changing gearbox/diff would not change speedo reading. As for the auto computer i never thought it would have any issues with the diff ratio being changed? after all wont it be looking more @ rpm and speed and throttle position?
  • Like 1
https://www.sau.com.au/forums/topic/279164-auto-diff/#findComment-4719012
on newer cars like ours the speed is taken after the diff. older cars like S13/S14 had a gearbox sensor.
and yes the auto tranny shouldnt act any differently, youll either accelerate faster or slower depending on the ratio off the diff. that said, the gearbox might slip more with a taller final drive....
  • Like 1
https://www.sau.com.au/forums/topic/279164-auto-diff/#findComment-4719542
No there should be no change as the ABS sensors are on the wheel side of the diff.
Great! now all I need to know is if I can simply install a S14 MT diff centre in my V35 and all will be good with no more single spinning badness
  • Like 1
https://www.sau.com.au/forums/topic/279164-auto-diff/#findComment-4720996
  • 5 years later...
Would my CVT (GT-8) be open diff as well then???
I am assuming open diff means Non-slip Differential???
As I want to do a Diff Flush but stuck in finding out if to get AmsOil (75W90) Normal GL-5 LSD Diff oil or NS (non-slip) GL-5 Diff Oil???
https://www.sau.com.au/forums/topic/279164-auto-diff/#findComment-7525298
LSD it is for the GT-8 & 6MT...
Best Ever Spec Sheet!!!
Thank you so much Greg :) AAA+++
PS. Do you read/write Japanese?
To do the same and source out a workshop manual in English in any format as I can only find a Japanese CD Workshop after countless searches! :(
https://www.sau.com.au/forums/topic/279164-auto-diff/#findComment-7525726
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
    • Do you have a picture? I assume it is a breather for gearbox oil as it expands, it should have a vacuum line run nice and high in the engine bay (R32 GTR has it on a top bellhousing bolt)
    • Hi all, I am putting an r33 gtst gearbox into a VL and have noticed what looks like a vacuum barb on the box (on top in the middle). Suspecting that it's a vacuum line but I'd like to double check, if someone could confirm the function of that would be great. Cheers in advance.
