Hey,
I have managed to locate some yellow jackets which are being sold second hand. Problem is the seller does not know whether they are S1 or S2? Does anyone know what to look for to tell the difference?
I noticed that my original coils have a tab on each side midway on the plug. The Yellows have one higher up. Does this help?
Cheers and thanks so much in advance,
L
https://www.sau.com.au/forums/topic/279174-yellow-jackets-s1-vs-s2-rb25det-r33/
Assuming these are pics of the actual coil packs. It looks like the S1 has the black mounting bracket all the way around. and the S2 does not.
pics from performance-wise website.
Series 1
Series 2
Edited by Munkyb0y
Yep, series 2 have built in igniters so they only have the mounting bracket on the ends, not all the way around.
Thanks guys. Does anyone know if original R33GTST S2 coils also have 2 mounting brackets or do they have 4? I'm now confused as to which one mine is as I thought is was S1 but could be S2. Made in 04/95 with Type M kit.
You can tell if you have series 1 or series 2 by looking at the back of the rocker cover. If you have a black box on top of the cover with wires coming out of it, you have a series 1. If you don't have this black box, you have a series 2. Chances are if you car is 1995 it will be a series 1.5 which uses series 2 engine and therefore coilpacks.
Series 1
Series 2
You are 100% correct :thumbsup:
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
