Lots of people must have a series 2 RB25DET with an adjustable exhaust cam gear. Has anyone done the testing to determine the best setting? That is has anyone done a series of dyno runs where the only variable was the setting of the exhaust cam gear?
I have one on my Stagea with basic mods: 3in turbo back exhaust and GCG highflow turbo which will be running 1bar (about 16psi) when i install my Z32afm and 550 injectors. It is currently set at 4 (crank) degrees retarded as per SK's suggestion. Unfortunately he never got around to the dyno testing to find the optimum setting. Surely someone has done it? If you haven't I would still be interested to hear what you have set it to but i really want a setting based on real live testing.
Thanks!!!
https://www.sau.com.au/forums/topic/279188-adjustable-exhaust-camgear-setting/
There is no hard and fast rule as to the setting. Each engine will respond differently to changes in cam timing.
Let your tuner and the dyno tell you where the cam timing needs to be for best performance.
You didnt dyno test for the best settings? jebus...
As per what Noel said - every car = different.
Some like neutral, some like 2 degrees, some want 4 or 5. You should test - not just go on someone else's suggestion
Thanks!!!
I haven't tested it on the Stagea, but I have tested it on a number of RB25DET's in other cars with GCG high flows. The -4 degrees is the most common setting for improved reponse, slightly faster boost build and slighty more power from around 3000 rpm to 5000 rpm. Of course you get nothing for nothing, so there is a slight loss of power from 5500 rpm to 7250 rpm. So the setting is dependant of what you want to achieve and it does vary sometimes from engine to engine. As always I would treat the -4 as a place to start, then tune from there.
Cheers
Gary
I just got my adj gear in the post.
Its -4 retarded at the crank right?
so the adjustment would be 2 of the little notches if the inner wheel was turned clockwise - that being if each notch = 2 degrees of crank
thanks
BTW a good post on dyno gains from this is at:
camgear
Thanks for the link but three pages of posts didn't tell me anything that i didn't already know - that an adjustable exhaust cam gear on an RB25 DET can give you a few extra KW. What I really wanted to know is if anyone has done the hard yards and tried a number of different settings to see which gives the best result. It is a pain to do because you have to take off the cas and put it back between each run but as has been pointed out before it is the only way to optimise the setting for your car. I will be doing it this weekend and will see if i can pick the best spot with road testing. If not it will have to wait until I get on the dyno in a couple of weeks. I'll report back!
I doubt you'll find power in the top end... the only thing you might find is midrange improvements with the adjustements.
How much gain is subjective as you already know, peka power really shouldn't change :banana:
How much gain is subjective as you already know, peka power really shouldn't change :P
Not really looking for more top end - want more in the mid range. I don't believe in subjective improvements (it feels faster etc). I would be looking for measurable improvement e.g. on the road i will be measuring 60 to `120 times in 2nd gear or on the dyno actual kw.
i wonder what mine is set to, i know dr drift said the factory position was best but i wonder if its different
ive got the bass junky factory hack cam gear adjustable thingy on mine
my top end does feel a bit flat ish - always has and my car never made mega power, 191rwkw was its peak
but the response and low down power is absolutely amazing - even with 213kms on the clock now, its still got amazing response
standard rb25det with usual mods, std turbo, std cams, cam gear adjusty thingy, assloads of ignition timing (peaks near 53deg) on the map
but im dead certain the CAS is backdialed a touch too
Might be a stupid question but... my cheap brand adj gear has the R on the left and A on the right of its adjustment.
BUT looking at pictures of HKS adj gears it is the other way around
For example look about half way down this following ad for parts, he is selling a cheap brand gear but behind it there is a HKS gear box--the markings are opposite.
ad with adj cam gear
Whats the deal.?
The motor turns clockwise(looking from the front) so the cheap gear it correct, ummmm, is it?
Whats the deal.?
You don't have a picture of your cheap cam gear. The one in the photo is correct in that it shows degrees of retard (or advance) correctly on the scale i.e. to retard cam timing you turn the adjustable pulley anticlockwise and the correct reading will line up with the mark. Maybe your cheap pulley is indicating the direction you need to turn the wheel rather than showing the correct scale for adv or ret.
Here is a pic of my cam gear...
If I turn the inner wheel counter-clockwise, it will indicate A(advanced) on the marks..
So this is wrong?
Yep it's wrong, HKS have it right
Cheers
Gary
    • A seat I find stupidly comfortable to sit in is the one in a friend's Merc Race Car. It even has the huge wings that wrap around your head. Best ever. Only issue is climbing through his scaffolding he put up in the doorway of the car... Ha ha ha. I sat in that seat for a couple of hours doing wiring. Another stupid comfortable seat I find, especially if my back is aching, is my OMP fixed back bucket seat too. I'll just sit on it when I'm exhausted in the garage sometimes to relax!
    • I just got off the phone with Dean from Vosta in Brisbane. They are the ones that do the replica seats and they have a shop full of seats for my to try out. Lovely guy.  I haven't decided whether to go genuine or replicas, I'm leaning towards Genuine at this point but who knows.  Also thinking the STRADIAs are the way to go VS the GIAS since they have a lower hip edge and would be easier to get into. Don't really like the idea of arm rests on the models to the right of this diagram either, maybe they can be removed?
    • From my own first hand experience, keeping power for a fun Street able skyline down at a responsive low 200 wheel KW, is the best. It makes it super drive able through the twisties, you're not just smashing mass wheel spin, or only able to open the throttle for a split second before being at absurd speeds. That said, plenty of people like being morons at more than double the speed limit on public roads and hence are happy with 600whp and seeing 200kmh fly up frequently and fast. Also, at that low 200, a GTR can still do a decent quarter mile, and with a bit of fancy  clutch work (foot, not the parts) can still beat many many cars in a traffic light gp, even in the wet.
    • Good news. So it went up to 16.2 volts as per the manual then dropped to 13.6v where it maintains that voltage. The sizzling sound stopped after that. All is looking ok. Car starts up same as usual.
    • As strange as this sounds (as they are fixed back), my Bride Xero CS seats are the most comfortable seats I've used.  I vote go genuine.  The only downside I've found is on very long drives, you can't reposition your body while driving. So even though its comfy, being locked in the same position eventually becomes uncomfortable. I find myself stopping every 3 or so hours to stretch my legs on long drives.
