Hey Guys,
I am new to this site and looking to buy my first Skyline (R33 Gts-t) and was wondering if anyone had any pointers on what to look for while purchasing one of these cars or of any good places to buy one from?
I'm looking to Buy a slightly modified 33, if anyone could shed some light it would be greatly appreciated!!!
Thanks
https://www.sau.com.au/forums/topic/279244-car-hunting/
Hey Guys,
Thanks
http://www.skylinesaustralia.com/forums/bu...e-f-t35129.html
15k will land you a very nice, clean R33 GTST with some tasteful mods. A few more grand and you can even get yourself a nice R34 GT-T.
https://www.sau.com.au/forums/topic/279244-car-hunting/#findComment-4716197
Thanks mate, great help! Now the hard part of trying to find a nice one ;)
That's the easy part.
There are 11ty billion 33s in Melbourne. Too many r33s + recession= Buyers market. You can be picky as. :)
Just get it thoroughly checked out by a reputable workshop prior to purchase and you should be sweet.
https://www.sau.com.au/forums/topic/279244-car-hunting/#findComment-4716220
15K for a modified 33GTST will be a little hard mate. any modified car you get its best you go over it with a fine tooth comb to make sure your not buying a dudd. and for that budget im sorry to say this but it will be hard trying to find a nice clean well looked after modified car.
being your first R33 why not try looking for a stock R33 series 2 skyline? you can get a nice clean one for around 12-15K and mod it your self.
main thins to look for is the service history of the car, if its been well kept, quality parts used, engine condition. prop best to do a compression test. if you want get the turbo checked out for shaft play at the same time.
but being your first skyline don’t by a modded 33 at that budget as a first car. or increase your budget.
https://www.sau.com.au/forums/topic/279244-car-hunting/#findComment-4716226
Im not sure what cars you have previously owned but make sure you are careful if you do buy a modified skyline as your first one....They can be a handful if you don't drive them sensibly.
I agree with ashneel, buy a stockish one and then modify it yourself, that way you know whats been done to it and can work your way up from there. That what i did and im glad i chose that option rather then buying a modified one straight up.
Either way make sure you test drive a handful so you can compare them and find a good condition skyline!!
https://www.sau.com.au/forums/topic/279244-car-hunting/#findComment-4716252
but being your first skyline don't by a modded 33 at that budget as a first car. or increase your budget.
+1
At least that way you know the mods that are going ON the car are decent quality parts also. Look as critically as you can - there are many, many 33s out there atm that arent even worth looking at cuz theyve been abused by careless owners :iluvff:
https://www.sau.com.au/forums/topic/279244-car-hunting/#findComment-4718367
there are good number of modified 33s with great mods which will save you a bucket load i.e. >20k so why not look at those? These days buying a stock r33 is a waste of money as so many good ones avalibale at incremental cost.
Yes and no.
You can save money but at the same time is just a waste of money in itself. Who knows what the previous owner has done to the car, If there were short cuts or the mechanics who worked on the car were even legit. Could of been a backyard job for all you know.
Purchasing a stock R32/R33 or whatever Juzzy wants, Means he can get a clean example of a stock R33 in a certain price range then look at what he wants then go ahead and modify it how he wants. At least then HE knows what hes done and whose done the work.
Ill be looking at a stockish R32/R33 for cheap then throwing out 15k on it mainly for the fact I want to watch the process take shape and know that MY mechanic has done the work; Not some first year Immigrant named Habib.
https://www.sau.com.au/forums/topic/279244-car-hunting/#findComment-4721535
Yes and no.
dood the generic stuff is a bit old. who say's you dont know what and who has modified it? if yu dumb enough to buy it without a known histroy then thats the buyers issue.
again, there are many good modified gtst's out there many from this club from known workshops. Total waste of money starting from stock and spending anotehr 20-30k on mod over a few years for a car worth 10k stock these days. Like many of the more serious owners like myself who HAVE done this an are running 300+kw gtst's with all the mods and I would not do it again to this car. I would buy a well modified upfront, save 10-15k and go from there.
https://www.sau.com.au/forums/topic/279244-car-hunting/#findComment-4721915
totally agree
you should be able to find a clean, well modded R33 GTSt for 15K easily... my mate bought his 6 years ago for 14K... also ask around at some of the more reputable workshops, they may know of customers in the market to sell their cars
https://www.sau.com.au/forums/topic/279244-car-hunting/#findComment-4724077
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
