Hi Guys,
anyone ever attempted to perform this conversion?
im quite keen as i love the r34's interior, but dont want the heavy r34 (or maybe i just cant afford one)
would like to know whats involved, what do i have to do to make it work?
i'm looking to change the entire dash, door trims etc.
including making the r34 speedo cluster work with the r33 sensors and ecu...
any help appreciated thanks :P
https://www.sau.com.au/forums/topic/279333-r34-gtt-dash-conversion/
ummm thats odd but just might be a worthy project...i have never heard of anyone doing a dash conversion....if you do please keep us informed as this would be rather interesting....
1 would assume that it would require a lot of work....also does your 33 have airbags?
ohh and then getting your sensors to work shouldnt be that much of a headache
goodluck mate
goodluck mate
cheers thanks, yea the r34 interior is fakkin mint, personally, i think the GT-T cluster looks better than the R34 GT-R Cluster.
really hoping this will work out, if anyone knows anything, any help will be appreciated.
thanks :P
fours and more in SA claim they've done a r34 gtt dash conversion into a silvia but they did an engine swap as well
so if it might be doable
I was thinking of doing this a while ago but gave up b4 i started to really think about it...
I personally dont think it'd be worth the effort.
Owning a R34 and have been in a R33 I dont think it's THAT spectacular that you need to change, nothing that a set of DEFI gauges and a double DIN screen HU cant solve :)
I would save the money for something else!
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
